Old 09-25-2009, 07:05 PM   #1
crazyfireman
Drives: 2010 Yellow Camaro
Magnaflow, cat back problems
Hey everyone I have a 2010 6.2L with a 6 speed auto tranny. I installed the muffler delete Magnaflow cat back kit and am having a problem. At low RPMs the exhaust tone is changing and it sounds bad when it does it. It acts like it is missing and I am aware of the fuel management system where it shuts down cylinders but this change in tone is sporadic and I would think the fuel management would only be in the upper gears and at highway speeds. My local dealership is pathetic and they said there is nothing wrong and I need some opinions...
crazyfireman is offline   Reply With Quote
Old 09-25-2009, 08:38 PM   #2
norcalwheelman
norcalwheelman's Avatar
Drives: 2010 Camaro 2SS/RS Victory Red
It's the AFM, my L99 A6 does the same thing at low speeds. It is annoying to say the least. Your exhaust just makes the sound of the AFM more noticeable since the Magnaflow catback removes the mid resonator. This is why I am going with an axle back setup, from what I have been reading the cat back offers no increase in HP or torque.
norcalwheelman is offline   Reply With Quote
Old 09-25-2009, 10:39 PM   #3
ttss
TTSS
Drives: 2010 Black on Black SS L99
I have the MF 3 inch cat and it does the same. It actually sounds worse at low speed and rpm with a light load than highway speeds. I dyno'd the car before and after the cat install and picked up a min of 8 hp and an avg. of 10. I had already installed a CAI previously but did not dyno before installing it.
ttss is offline   Reply With Quote
Old 09-25-2009, 10:41 PM   #4
ffrcobra_65
There are a lot of information on here about the SS auto tranny and cat backs. It is just something you'll have to deal with or get the AFM tuned out.
Old 09-26-2009, 12:19 AM   #5
crazyfireman
OK I appreciate the info
Old 09-26-2009, 01:46 AM   #6
camaross14
camaross14's Avatar
Drives: 2010 ABM 1SS,2008 Silverado
i had a 08 silverado with the AFM and it would tell you when it went to 4cy mode ...as sson as u hit the break to slow down it cuts it back
camaross14 is offline   Reply With Quote
Old 09-26-2009, 07:28 AM   #7
SGOS252382
SGOS252382's Avatar
A lot of L99 owners are finding out about AFM the hard way. Any aftermarket exhaust (especially muffler delete setups) are going to cause an increase in
AFM noise. The more aggressive the setup the worse its going to be.
It's most noticable around 1800 rpms while cruising. You'll hear the AFM kick in and a change in exhaust note (along with a drone/buzzing sound in some cases).
1. Put the stock mufflers back on the car (but who wants them?)
2. Get the AFM turned off (requires tuning).
3. Live with the noise
Old 09-26-2009, 09:32 AM   #8
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
I have the SLP LM II axle-back. I get the pitch and vibration change when in the higher gears at any speed. Using the tap shift helps by driving at higher revs. I plan on getting AFM tuned out.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
My Baby is home! 2SS/RS Black w/IOM Michael_Js Member Car Journals 144 08-13-2011 05:41 PM
Magnaflow Exhausts - FREE Shipping tbyrne V8 Bolt-Ons & Tunes 1 09-11-2009 11:11 AM
My Zoomers CAT Back Exhaust install - 09/09/09 Michael_Js Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 09-10-2009 10:33 AM
Cat back or axle back? norcalwheelman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 07-22-2009 09:15 AM
Cat back gains? 8ty8 ls1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 07-21-2009 01:46 PM
