09-25-2009, 07:05 PM | #1 |
Drives: 2010 Camaro 2SS RS M6 CGM A9125214 Join Date: Jun 2009
Bigger Diameter Wheels setting Wheel Speed Sensor DTC and ABS Light
A friend installed 24" wheels on the rear of his car that are a different diameter than the stock tire and wheel combo, as soon as he hits the brakes the abs light comes on and a DTC for wheel speed sensor is stored in the brake control module, is there anyway to adjust the wheel size using an MDI or does it need to be programmed by HP Tuners or similar?
