Old 03-15-2016, 08:52 AM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Question Stock Harmonic Balancer Reliability???
As far as the OEM crank pulley how is the reliability of it on high HP builds? Is it a weak point in the LS3 as far as breaking or is it nothing to worry about? I'm talking primarily for drag racing
booneSS13 is offline   Reply With Quote
Old 03-15-2016, 09:19 AM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Pin it....There are better options, but at least have it pinned when you change the cam or go FI.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 03-15-2016, 12:38 PM   #3
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
we ended up changing it out when we went twin turbo. I'm around 800 hp on 6 psi, old one wasn't cutting it.
2011 Victory Red 22/RS
Forged 418 Ls3 from Texas Speed, LSX heads from Texas Speed, Tick Turbo cam, Jakes/PCM/Billet 4l80e, 3200 Stall converter from Circle D, DSS 750 hp axles, DSS aluminum driveshaft, stock 3.23 gears, TSW Wheels Front 20x10 Rear 20x11.5, Fabberage Twin Turbo Supercharger Killer kit with Upgraded Turbos, Squash Dual fuel pump, Full BMR Suspension/bushings, Holly High Rise intake manifold, ID1300 Injectors, Megan Coilovers, PCM of NC plug and play trans kit. HP/TQ TBA
DaFisch is offline   Reply With Quote
Old 03-15-2016, 06:14 PM   #4
booneSS13
booneSS13's Avatar
What do you mean by it wasn't cutting it? What was going wrong with it?
Old 03-15-2016, 06:15 PM   #5
booneSS13
booneSS13's Avatar
What is "pinning"??
Old 03-15-2016, 06:27 PM   #6
68rssscamaro
Camaro: A Legend Reborn!!
68rssscamaro's Avatar
Drives: SOLD: 12 2SS/RS LS3 45th
Originally Posted by booneSS13 View Post
What is "pinning"??
http://www.camaro5.com/forums/showthread.php?t=109487
[SIGPIC][/SIGPIC]
68rssscamaro is offline   Reply With Quote
Old 03-19-2016, 09:47 PM   #7
booneSS13
booneSS13's Avatar
Originally Posted by 68rssscamaro View Post
thanks a lot
capacity, durability, high power, stock, torque
