![]() Drives: 2015 Chevy Camaro LT! Join Date: Jan 2016
Hissing sound on passenger side
About 2 weeks ago I was on my way to work and when reaching 3000+ rpm's I started to hear this hissing noise with like a slight grind to it. It has bugged me and won't stop. Only hear it when car is moving and has reached 3000 rpm. The check engine light has not came on and the car is only at 38,000 miles (would be just passed factory warranty). Is there a perso. That has fixed this on their own. If not do you know what it is.
Here is the YouTube link of a video I took in my car
http://youtu.be/__px6tyEadY |
[QUOTE=GDelToro;8970015]Here is the YouTube link of a video I took in my car
Silver Ice
Unfortunately it may be a bad heater core. Look it up the sound and description make me think it is.
#6 |
![]() Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
maybe this?
Tech service bulletin. # PIC5984: Hiss Noise Or Gurgle Noise From Dash - (Apr 9, 2014) Subject: Hiss Noise Or Gurgle Noise From Dash Models: 2013 - 2014 Chevrolet Camaro The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. Condition/Concern Some customers may comment that a noise can be heard from the dash area while the engine is running. It may be a hiss noise or a gurgle noise that can be heard. Raising the engine RPM may or may not change the sound of this noise. Recommendation/Instructions This noise may be coming from the cooling system in the vehicle. If a noise can be verified and it sounds like it may be coming from the heater core, dealership technicians are to remove the inlet hose of the vehicle's heater core. There will be an inlet screen installed in the core that may be plugged with debris, causing this noise. Using a pocket screwdriver or a small pick, remove the screen and inspect it to see if it is plugged with debris. If this screen is found to be plugged, it will need to be cleaned or replaced. In addition to this, the vehicle's cooling system will need to be flushed out and refilled. If a lot of debris is found in the inlet screen, backflush the heater core as well. Regardless of the repair direction, the air will need to be bled from the cooling system, and technicians are to evaluate the customer's concern again at that point. |
#7 |
![]() Drives: 2010 Camaro SS (Black) Join Date: Aug 2015
Check to see if there are any snakes.
#8 | |
#9 |
Could it be a snake?
With great power comes with responsibility. However with great horsepower comes a hell of a lot of speeding tickets.
#10 |
I solve problems for a living. Either accept my advice or go figure it out on your own.
#11 |
This is the rest of the bulletin. I really don't know. i have never messed with them. I dont work on them but I have access to the TSB were I work. There is a lot in there thats for sure. i checked my truck and found out most the issues i have on it have been addressed but i waited to long and all of them are outside the period to get them taken care of. Guess I need to review them more often. If still under warranty bring it to the dealer.
"Do not replace the heater core for a noise issue. This is a very extensive procedure which requires the removal of the windshield. If a heater core is suspected for a noise concern and the filter is free of debris, backflush the heater core and inspect to see if any additional debris was trapped in the heater core. Bleed the cooling system and evaluate the customer's concern" |
#12 |
![]() ![]() ![]() Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
#13 | |
![]() Drives: 2017 Camaro ZL1 Join Date: Nov 2014
#14 |
Silver Ice
Jees. Trolls galore lol. I approve. But back to the topic. Like i stated, its probably a heater core. Someone else mentioned what I was gonna advise next. Which is do not replace for just the noise. If you lose A/C then change. Its expensive and requires the mechanic(s) doing the repairs to pull apart your entire dashboard/windshield, etc..
| Tags |
| 2015, acceleration, camaro, noises |
