Old 03-18-2016, 08:27 AM   #1
Speedfreak391
One man Army
Speedfreak391's Avatar
Drives: 1987 Iroc Players car
Choices with Whipple
Ok, here is the question. I have a 2010 L99 car that I have just converted to ls3 with the LS9 cam, lifters and valve springs. I am almost done with the whipple install and then I will be installing the LPE twin mechanical pump setup (the one that runs off factory wiring without the controller. Injectors are ID 850's, with a cold air, and Stainless power headers and Full magnaflow exhaust. Planning to to get dyno tuned in a week.
My question is What pulley should I run to be safe on the street with? I have the stock 4.00, 3.75, and a 3.50. I am not looking for a dyno queen I could care a less about a big number. I want as much power possible but want to be safe at the same time.
Thanks in advance!
1987 Iroc-Z with a turbo 5.3, T-56, Moser 9", and lots of other goodies.
http://www.mifbody.com/vbulletin/sho...87-IROC/page24
2010 Camaro 2SS/RS with a K&N cold air Stainless Power headers, Magnaflow cat-back, staggered TSW Nurburgring's just a great daily driver.
Speedfreak391 is offline   Reply With Quote
Old 03-18-2016, 08:39 AM   #2
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
3.75 pulley I ran 9.90 with your exact setup.
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 03-18-2016, 10:55 AM   #3
Speedfreak391
One man Army
Holy shit are you serious?
Old 03-18-2016, 11:07 AM   #4
cc-rider
Drives: 2010 Camaro SS
I don't think you want to run much past 9-10 psi with stock internals and running pump gas. Tough to say which pulley because you have a few mods there that will lower your boost as compared to a stock Whipple build. Call Whipple. Or call one of the vendors here who have done a lot of builds. They'll tell you which pulley will be best. Of the ones you have...I bet the 3.75 pulley is the one.
cc-rider is offline   Reply With Quote
Old 03-18-2016, 11:59 AM   #5
ToddB
Drives: 2011 2SS Convertible Supercharged
I run 3.625 at 13 lbs. with meth. Mods in sig. Would not go over 10psi without meth.
ToddB is offline   Reply With Quote
Old 03-18-2016, 01:15 PM   #6
Speedfreak391
One man Army
I don't really want to run meth anyway. I would like to stay under 10 psi. I should be able to finish the complete install this weekend. I bought a used setup, and have had to source some misc. parts here and there. But I think I have everything now. Doing the heater hose hide tonight, since the stock hoses don't really work with the whipple. I also have to install the fuel pump and the rear cradle bushings. This weekend will be busy since I have to work on Sunday.
Old 03-18-2016, 05:57 PM   #7
2SSLincolnSS2
SoCal
2SSLincolnSS2's Avatar
Drives: 2011 SS2
I have a rough idle blower cam, 2" headers, Whipple (3.875 pulley), ID 850's, cold air, Corsa 2.5", ZL1 pump, and an ADM FPCM.
I am running 9.9 lbs at 6600 RPM with that setup and 640rwhp on 91 octane.
*If I could do the fuel pump over, or if I ever have to, I will cut a hole in the back seat sheet metal. I had to drop the whole rear-end out of the car. Good luck trying to get the evap box out without dropping the rear.
<a href=http://www.camaro5.com/forums/picture.php?albumid=9810&pictureid=82873 target=_blank>http://www.camaro5.com/forums/pictur...ictureid=82873</a>
2SSLincolnSS2 is offline   Reply With Quote
Old 03-19-2016, 10:24 AM   #8
TOSTO RACING
NHRA
TOSTO RACING's Avatar
Drives: ZL1
2017 ZL1 Twin Turbo
1300 Rwhp
NHRA 5664
TOSTO RACING is offline   Reply With Quote
Old 03-19-2016, 12:06 PM   #9
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
I'm currently at 13-14 psi with a 3.625 pulley, 10 percent lower, e85 tuned with flex fuel sensor upgraded, fore dual pump, made about 9-10 passes at the track, car runs great and is tuned very safe not making 800 rwhp, but on a better dyno or climate, would make that kind of power, def. look into getting suspension, clutch, traction, and have spent a lot more money into building suspension lately, building lsx block now with built internals.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 03-19-2016, 06:08 PM   #10
TOSTO RACING
NHRA
Drives: ZL1
What kind of mph did you have at the track and what rwhp did you make ?
2017 ZL1 Twin Turbo
1300 Rwhp
NHRA 5664
Old 03-19-2016, 06:36 PM   #11
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
No dyno Queen here running a 3.75 pulley. In good air running 10.10 @ 135 in the 1/4
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 03-19-2016, 11:24 PM   #12
Speedfreak391
One man Army
Wow, That is a ton of power. I called whipple and they told me to run a 3.500 pulley to be around 10psi with this cam, headers and exhaust. I am thinking that may be a little drastic. I just really want to be as safe as possible. Hearing what you guys are seeing with 3.875 and 3.625 pulleys I am thinking the 4.00 is probably the safest way to go if I would like to stay 8-10 psi.
Old 03-20-2016, 09:18 AM   #13
94guy
I have used 2SSLincolnSS2 JREcam in a few cars with a 6sp manual and 3.5 pulley 10.40'@136-137. The manual car made 725rwhp.
2010 Camaro
Old 03-20-2016, 04:59 PM   #14
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
a lot depends on elevation where you are at. I am running the LS9 cam, 1-7/8 long tube headers, and full 3" exhaust. When I lived in Albuquerque, about 6000' feet above sea level, the stock 4" pulley was only good for 7 psi. I switched to the 3.75" and I came back up to 9 psi. Now that I live in North Carolina, about 350' above sea level, that same 3.75" pulley has me making a little over 11.5-12 psi. I am tuned very safe, and the car makes 650 RWHP on 93 octane.
If you want to remain below 10 psi, stick with the 4" pulley. You will lose about 1 psi of boost for every 2000' of elevation, and according to Whipple, gain about a 1 psi of boost per .125" reduction in pulley diameter.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
