Old 03-19-2016, 06:30 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Question Any 2 stage nitrous setup users here?
For those of you who have experience with nitrous setup, how much would running two stages help your time on a 200 shot? I'm on 20's with an m6 and drag radials and would like to get low 11 's high 10's if possible. I know traction and axles will be an issue, But what if I were to spray 100 shot on the first stage and then spray 200 on the 2nd stage at maybe 3rd gear?
booneSS13 is offline   Reply With Quote
Old 03-19-2016, 07:59 PM   #2
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
just use a progressive controller on a 200 shot, less stuff to buy. ramp it in slowly
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 03-19-2016, 09:27 PM   #3
booneSS13
booneSS13's Avatar
I do plan on purchasing that NOS mini 2 stage progressive controller. the only reason I debated on a 2 stage setup with it is because I have a Ls3 plate laying around so I figured I might as well use it if it's not too much trouble.
Old 03-21-2016, 08:18 PM   #4
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
? You can still use a plate with a progressive system.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
1/4 mile, launching, nitrous camaro, nitrous outlet, nos
