Old 03-21-2016, 08:36 PM   #1
monte1214
monte1214's Avatar
Drives: 2013 Camaro SS Convertible
Anyone have this?
My car is lowered with the 3" exhaust, but I still have the stock "plates".
Does anyone have this, and can comment?
http://www.phastekperformance.com/20...moly-brace.htm
monte1214 is offline   Reply With Quote
Old 03-23-2016, 11:52 AM   #2
dbauer
dbauer's Avatar
Drives: '11 2SS/RS LS3 M6 Convertible
I've got one, had it on about two years. It will definitely give you more room for your exhaust, which is why I purchased it. It is also more rigid than the two steel plates that it replaces. My only issue was that I had to modify it a bit to get it to fit. I had to have a couple of the holes widened about 1/2" so that I could get the bolts through all of the holes. Was it worth $500? Not if you are going to modify and upgrade your suspension as well, but I knew I wouldn't be doing that for several summers anyway.
dbauer is offline   Reply With Quote
Old 03-23-2016, 12:39 PM   #3
monte1214
monte1214's Avatar
I'm lowered and have the 3" LG Motorsports Exhaust.
I'd like to gain some clearance with the brace but not sure it'll help?
Old 03-23-2016, 01:08 PM   #4
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
It will reduce your ground clearance slightly, if that is what you are asking.
2012LS3VERT is offline   Reply With Quote
Old 03-23-2016, 07:20 PM   #5
monte1214
monte1214's Avatar
Oh, ok...I was wondering if it'd give me a little more clearance than I have already.
With the lowered Vert and those plates, I rub alot.
Old 03-24-2016, 09:21 AM   #6
bsimms89
bsimms89's Avatar
Drives: 2012 SS/RS Vert & 2017COPO#23 SC350
I've got one too and its exactly like he said, I needed to open a couple of the holes a little to get it to line up too. And yes you will lose a little clearance, its to give you more room between the tunnel and the brace so you can fit a bigger exhaust without hitting the brace.
2012 IOM Camaro Convertible 2SS/RS, A6/L99, ARH Longtube headers, high flow cats, x-pipe & mufflers
CAI Cold Air Intake, Kaltech Tuned
2017 COPO #23 Black w/ Supercharged LSX350
2014 Raptor 6.2L Tuxedo Black Metallic w/ 2.9L Whipple, 78Lb/hr fuel injectors, Ford Racing Dual 65mm cobrajet throttle body, kooks headers & exhaust.
1969 Camaro SS (original SS350), Black w/ white Rally Stripes, new ZZ502ci 502hp motor, muncie 4 speed, 4.11 rear
bsimms89 is offline   Reply With Quote
Old 03-24-2016, 09:40 AM   #7
monte1214
monte1214's Avatar
So...the Brace is "thicker" than the plates then, making the car sit lower?
Old 03-24-2016, 11:53 AM   #8
dbauer
dbauer's Avatar
The brace is tubular steel, and will hang lower to the ground, allowing for more space between the bottom of the car and the brace, making room for bigger exhaust. The steel plates it replaces lay straight across, where this brace gives more space.
The car itself doesn't sit lower, but the brace hangs down lower than the steel plates it replaces.
Old 03-27-2016, 05:31 PM   #9
2011WhiteSS
2011WhiteSS's Avatar
Drives: 2011 White 2SS
Anyone have this?
I have a 2014 SS A6 Convertible. I installed TSP 2" Headers/TSP 3" Exhaust.
After the install of the full TSP exhaust none of the factory crossmember plates or braces wouldn't even come close to bolting back into place. There is 3 OEM flat plates. Front/middle/tunnel. Along with that there is 2 metal strips that tie at 3 points into the corner of the rocker panel and the front cradle bolt and the rear convertible trunk well.
I bought the Hotchkis Chassis Brace thinking this would be perfect to solve my issues.
I even bought and installed the optional 1/2" spacer to give it better clearance for the 3" exhaust and it STILL rubs on the tunnel plate.
Even though it is pushing the X-pipe up and is laying on the center section of the Hotchkis brace, it helped tighten the chassis up but only in the rear. The front seems as if it's loose and twisting. I see and feel ALOT of cowl/windshield shake.
I was able to machine some spacers 1.125" to use on the rear most mounting bolts for the convert strips mentioned above. And just that was noticeable difference in tightening the rear feel of the car. (I prob push the car to its limits more than most so I do feel the small differences that these changes make.)
So I'm thinking this ARH brace would give the needed clearance at the tunnel and take care of the middle brace that's missing and if I remove the middle section of the Hotchkis Kit I could keep the trianglated left/right pieces. Then either space the last front crossmember or get a front subframe/cradle brace or both. Lol
Is it possible to brace and stiffen a chassis TOO MUCH??
2011WhiteSS is offline   Reply With Quote
