Old 03-22-2016, 12:45 PM   #1
sir574
sir574's Avatar
Drives: 2017 SS 1LE
Exclamation 2011 A6 trans & diff fluid change help
I've searched and searched... and can not find a guide with pics on how to change out both of these, and how much fluid I need for both.
thanks!
sir574 is offline   Reply With Quote
Old 03-23-2016, 03:48 PM   #2
sir574
sir574's Avatar
Drives: 2017 SS 1LE
bump
Old 03-23-2016, 07:26 PM   #3
fhrex
Drives: 2011 Camaro 2LT/RS
6.7 qts of Dexron VI for trans service.
195mm and 218mm axle: 1.1qt, 250mm axle: 2.1qt. rear axle lubricant.
Don't forget additive if you have the 218mm limited slip rear: 3.3 oz
fhrex is offline   Reply With Quote
