Old 03-22-2016, 11:21 PM   #1
FastGirl
FastGirl's Avatar
Drives: 2013 2LT/RS
6th Gen Steering wheel in 5th Gen?
Anyone know if a 6th Gen Steering Wheel can be swapped into 5th Gen? or a C7 Steering wheel as I hear its the same...
FastGirl is offline   Reply With Quote
Old 03-28-2016, 11:45 AM   #2
BluePhoenix
BluePhoenix's Avatar
Drives: 23 Camaro 2SS 1LE
It would depend on whether the column is different, using different wiring harness connectors and the keyed mount in the center. You would literally have to see a 16 Steering wheel without the airbag and compare it to the style that is in yours.
One note on the 16 steering wheel, I noticed GM borrowed the Camaro logo & chrome trim from the 2010-2011 Steering wheel.
2023 Camaro 2SS 1LE, A10, Summit White,
1100 - 3/23/2023
2000 - 3/27/2023
3000 - 3/28/2023
3000 - 4/04/2023 — 4/24 TPW
3400 - 4/12/2023 — 4/24 TPW
3800 - 4/28/2023 - Delayed ETA
VIN: 1G1FH1R73P0145237
5/10/2023 - ETA 5/27/2023
5000 - 5/30/2023
6000 - 6/3/2023
2024 GMC Sierra 1500
BluePhoenix is offline   Reply With Quote
Old 03-28-2016, 05:25 PM   #3
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
And it look so much better.
Old 03-31-2016, 12:52 PM   #4
Graphicsgod
Graphicsgod's Avatar
Drives: 2015 Manual Hot Red 2LS Camaro
Waiting for a guinea pig...
I kinda like it (which is about one of the only good things about the 6th gens I like, I think the car is just fugly!!).. That and moving the door handle was the only good thing. And the trunk having more space is nice, otherwise ewww!!
Graphicsgod is offline   Reply With Quote
Old 04-01-2016, 04:20 PM   #5
ytown87
ytown87's Avatar
Drives: C6 Corvette
I was literally thinking about this same thing myself today. problem is finding one to even try it with
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
ytown87 is offline   Reply With Quote
Old 05-09-2016, 12:39 AM   #6
Yippee38
Yippee38's Avatar
Drives: '11 SGM 1LT/RS, '02 SOM Firehawk
More importantly, can a 6th gen HEATED steering wheel be swapped onto a 5th gen?
Yippee38
Yippee38 is offline   Reply With Quote
Old 06-28-2016, 05:40 AM   #7
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
I'm willing to buy a 6th gen steering wheel If someone can make it work. Probably need the clock spring too but I am very interested in the swap. I want to put a 6th gen heated in My 5th gen bad.
http://www.trunkmonkeyparts.com/oe-gm/23379912
Rainbow1616 is offline   Reply With Quote
Old 06-28-2016, 04:26 PM   #8
RichCamaro10
RichCamaro10's Avatar
Drives: 2010 Camaro 2SS
My guess is that the steering wheel that you have linked does not include the airbag. The airbag is usually pricey......
2010 Black Camaro 2SS
RichCamaro10 is offline   Reply With Quote
Old 06-29-2016, 09:49 AM   #9
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Originally Posted by Graphicsgod View Post
the moving the door handle was the only good thing.
The moving door handle? Interior or exterior? I thought they were pretty much the same. What's the difference?
TommyTheCat is offline   Reply With Quote
Old 07-09-2016, 07:18 AM   #10
Rainbow1616
Good point, never thought of that. I will look in to that as well.
Old 07-10-2016, 07:14 AM   #11
BluePhoenix
Airbag probably would run $350-$500 depending on who you buy it from
1100 - 3/23/2023
2000 - 3/27/2023
3000 - 3/28/2023
5000 - 5/30/2023
6000 - 6/3/2023
Old 07-10-2016, 02:47 PM   #12
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
Seems like the 6th gen steering wheel has a few more functions than the 5th gen. Electrically, that my be a bigger hurdle than physically mounting the wheel.
Low Saturn is offline   Reply With Quote
Old 12-08-2016, 11:13 AM   #13
Rainbow1616
I finally was able to compare the wheels in real life. They have the same number of button functions (except for the heated wheel of course).
I am about to order the wheel, air bag, and coil and give this a shot. Everything I read says the bcm does Not have to be reprogrammed. Therefore I am fairly confident I can make it work. I will report back here when completed.
Old 12-08-2016, 11:23 AM   #14
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Not a fan of the bulky 6th gen steering wheel, it was one of the first things I spotted in the interior and it threw me off.
SSEssence is offline   Reply With Quote
