Old 03-23-2016, 04:16 AM   #1
trasherseb
Drives: camaro zl1 black carbon sun roof
Mod turns very bad
Hi guys I find myself'in front of engine breaking after'mod and prog on the dyno.
Supercharger pulley 2,35, Injectors fic 1000, trx6 ngk spark plug, rotofab + air gulp, intercooler exchanger with electric fan from lingenfelter.
Afr commanded and read 11,1 / 11,5
Avance 15
Supergarger 14 /15 psi
iat 68 to 86 max
On a 2012 zl1 with 13000miles wich run 98octan
All original for the other parts
The breaking : piston 7 and 8 melted, spark plug also, sleeve on cylinder 8 has a loss of material 1mm deep 1cm long.
Is someone has faced this kind of problem with similar mod, I want to understand what happened. What solutions did you find.
Thank you
trasherseb is offline   Reply With Quote
Old 03-23-2016, 06:53 AM   #2
m1key1111
Drives: 2012 ZL1
I'm sorry for the loss of your engine. Did you datalog your session while on the dyno? If so, can you upload it so it can be reviewed? Do you have a copy of your tune to upload so it can be reviewed?
There are so many other variables like oil pressure, etc it would be almost impossible to diagnose remotely. The commanded air fuel ratio seems fine, the advance is very low for that boost level with 98 octane too, it doesn't appear you should have a problem. With it being the rear cylinders I would only suspect it had something to do fuel delivery (volume, pressure, etc).
m1key1111 is offline   Reply With Quote
Old 03-23-2016, 07:26 AM   #3
trasherseb
92 octane not 98
Old 03-23-2016, 07:41 AM   #4
trasherseb
A road test was done in the morning before dyno everything was fine we checked 988Nm(728ftlt) of torque on car calculator.
Old 03-23-2016, 08:10 AM   #5
Gearheaded
Gearheaded's Avatar
Drives: 2014 SS
You ran the engine hard without a tune?
Toys:
2014 SS - TSP 235/239, CAI, LT's, 12.2 @ 115 ("SLOWLY" chipping away ET)
2000 Trans Am - Bolt-ons 13.0@110 (sold)
2009 YZF R1 - Race bike (road course)(totaled racing)
2008 YZF R6 - Race bike (road course)(still own)
Gearheaded is offline   Reply With Quote
Old 03-23-2016, 08:13 AM   #6
trasherseb
It was already tune
Old 03-23-2016, 09:02 AM   #7
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
Fuel pressure seems to be the wild card lately. Some are adding BAP around 625 rwhp and others are getting away with close to 750 rwhp on stock pump and injectors.
Whos_Drivin is offline   Reply With Quote
Old 03-23-2016, 09:07 AM   #8
robrocketanski
robrocketanski's Avatar
Drives: ZL1 Convertible Auto
I have noticed this too. I wonder about it being a nice way for shops to sell an additional part but it also makes sense that the stock pump wouldn't be enough for around double the injector capacity.
robrocketanski is offline   Reply With Quote
Old 03-24-2016, 04:57 AM   #9
trasherseb
how can I send you the data files ?
Old 03-24-2016, 08:45 AM   #10
m1key1111
Drives: 2012 ZL1
If you have the tune and datalog in hptuners please email it to me @ mb3689@gmail.com and I'll take a look at it!
Old 03-24-2016, 01:12 PM   #11
trasherseb
It s done thank you.
Old 03-24-2016, 01:19 PM   #12
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
That's what I thought when I read this... This might be one of those examples where he SHOULD have had a BAP.
jayno20 is offline   Reply With Quote
Old 03-24-2016, 02:01 PM   #13
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Not really a wild card. I told people back in 2013 that they would have a fuel pressure drop if they increase the boost substantially. http://www.camaro5.com/forums/showthread.php?t=289332
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 03-24-2016, 02:02 PM   #14
Ex-Cobra Guy
Drives: 2013 CTS-V Wagon & 2010 SS (hers)
Should be using NGK TR7IX...
6 heat range is stock....
Ex-Cobra Guy is offline   Reply With Quote
