Old 03-25-2016, 03:47 PM   #1
BLURPLE2
Drives: 2014 Blue Ray Metallic 2LS
Lightbulb "Camaro" side lettering delete?
Anyone know the technique to deleting the side lettering? Plan on getting some black lettering or just leave the letters off.
Any advice is appreciated!
BLURPLE2 is offline   Reply With Quote
Old 03-25-2016, 03:49 PM   #2
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Fishing line or dental floss. Warm it up first.
All the best,
Jared Royce
801.545.4215
Old 03-25-2016, 04:11 PM   #3
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
I put down painters tape around the emblem and used a flat wide plastic trim panel tool. Used goo gone and a soft rag and gently rubbed until the residue was gone. Then when it was all cleaned up I used a scratch remover polish and a microfiber cloth to clean off whatever dirt and junk was left that made the ghost letters.
JerTM is offline   Reply With Quote
Old 03-25-2016, 04:23 PM   #4
BLURPLE2
I feel like using the trim panel tool would scratch the paint?
Old 03-25-2016, 05:23 PM   #5
8balldeluxe
Drives: 2010 Camaro SS Victory Red
Sharp wood chisel and a 3 pound hammer, they came right off.
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
8balldeluxe is offline   Reply With Quote
Old 03-25-2016, 05:40 PM   #6
JerTM
JerTM's Avatar
Patience is the key. Fishing line is an alternative that won't scratch the paint. But either removal method will require cleaning of residue and left over junk.
Old 03-25-2016, 06:07 PM   #7
Pete M
9 Year USMC Vet
Pete M's Avatar
Drives: 2014 1LT black on black
A lot of stuff done so far to make it look better and be more fun to drive.....
Pete M is offline   Reply With Quote
Old 03-25-2016, 06:27 PM   #8
BLURPLE2
no heating, just smack them right off?
Old 03-25-2016, 06:31 PM   #9
BLURPLE2
im most likely going with the fishing line method. thank you for your input!
Old 03-25-2016, 06:35 PM   #10
bleavens1962
Drives: 2014 1LS Camaro
I used 10lb braid finish line. Make sure you have some goo gone, and be patient. Removing the lettering is easy, getting all the residue off can take a bit of time. Would also suggest giving the car a good wash so that you can see if you got all the glue off, and get all the goo gone residue off the car. I did the removal in the shade
bleavens1962 is offline   Reply With Quote
Old 03-27-2016, 01:42 AM   #11
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
could I use a grinder.
JCunningham is offline   Reply With Quote
Old 03-27-2016, 12:37 PM   #12
bleavens1962
A flamethrower is another option
Old 03-27-2016, 01:32 PM   #13
BLURPLE2
ill just use a combination of all of these
Old 03-27-2016, 02:02 PM   #14
Mydivorcegift
Future Mopar Owner
Mydivorcegift's Avatar
Drives: 2011, 2SS/RS, Synergy
I actually sprayed some goo gone on the letters and let it sit for a bit then used a piece of dental floss. They came off easy and so did the leftover residue.
2005 GTO-IBM-A4-Sold
2011 Camaro SS/RS Synergy-1 of 255-Sold
You will be missed but you are in good hands!
2019 Challenger Hellcat
B5, Redeye, Widebody
Mydivorcegift is offline   Reply With Quote
cosmetics, delete, lettering
