More then meets the eye!
Vitesse question
I would like to know how the professional tuners feel about this product. Not trying to start anything, I Just feel if you get a good tune that this thing would be of no use. But if they (professional tuners) feel that this is something that is worth putting on a good tuned car I will definitely buy one.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
![]() ![]() Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
No professional is going say anything but buy my tune it's better than VTC, there have been countless post from guys that are tuned and still get the benefit from using the VTC
Only time were the VTC does not live up to exceptions is when you have ported TB with intake, the VTC still functions as advertised but the throttle response is already greatly improved from the intake and ported TB so it neglects the throttle improvement achieved by the VTC
Is your car tuned with Vitesse? If so did you feel any difference?
Is this thing the same as sprint boosters?
#6 |
I think I'm going to try this out. For the price. If anyone has one they want to sell, let me know have paypal ready.
#7 |
I installed this in my camaro which has a hypertech tune and it was a great throttle response. I like it
#8 |
I wonder how it would be with the 4.10 gears.
#9 | |
Prod tuners correct me if I'm wrong, but I expect to hear crickets. |
#10 | |
#11 |
Yes I'm tuned with the VTC, the tune only optimizes the AFR TO 12.5 TO 1 on wot and optimizes the ignition timing so there is no knock (predetonation) plus adds a few degrees of timing here and there but mostly just efficiency. The reduction of TM will let the power come through with out the spark or fuel being cut off to limit the power. I did feel a difference from both but not the same feel .the tune gave more power the VTC gave more response
#12 |
Those two feelings are easily mistaken for each other because the end result "feels" similar. I choose to have both because why not I personally like the fact I can control another part of my car
#13 | |
So if I get more bolt on that need to be retuned, I won't have to uninstall the Vitesse to retune my car, right? I get my tunes through email, no one on island has a dino, that's why I ask.
#14 | |
Nope you never have to touch it again ,the tuner won't even know it's there unless you tell him |
