Old 03-26-2016, 12:20 AM   #1
CALLAWAY11
CALLAWAY11's Avatar
Drives: 2011 2SS/RS Callaway
*Updated* E85 on stock fuel pump? RWHP guesses?
Okay, E85 was just installed on my car and it's using the stock SS fuel pump. I'm getting roughly 600 to the wheel right now. I'm also increasing boost from 8psi to 11psi. I'm changing my pulley and can't remember what size it is. I look at other members cars in that 650-700 whp and it seems that everyone has twin fuel pumps. It's getting put on the dyno Monday and will find out where I'm at. My car has been on the dyno multiple times, the first time I finished at 607 whp and that was on 275 stock tire and the second time finished at 575 whp on 305 drag radials. This time it will be on 275 drag radials. They said the tires played a small roll along with other factors. Any thoughts about the stock fuel pump and guesses where I'll end up?
Ok, found out some info today. There's a chance that my fuel pump wasn't a SS stock pump. When the car was purchased new it was sent to Callaway and they might have put a bigger pump in it. I will be going with dual pump system from Fore. Twin 450's. Can't wait to get this done. Any guesses on the RWHP?
2011 Callaway SC572 2SS/RS, TVS 2300 Supercharger, 1-7/8" Kooks LT Headers, Fast 85# injectors, E85 Flex Fuel Conversion, Fore Twin Fuel Pumps, MGW flat stick short throw shifter, McLeod RXT twin disc clutch, Liberty Gears Tremec trans, DSS 1000 hp axles, Nitto NT555r drag radials, 10#'s of boost, 702 rwhp/ 697 torque, Recaro seat upgrade
CALLAWAY11 is offline   Reply With Quote
Old 03-26-2016, 12:49 AM   #2
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
You'll end up on a flat bed tow truck soon enough.
Don't skimp on a fuel system after spending all that money..
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 03-26-2016, 01:03 AM   #3
cc-rider
Drives: 2010 Camaro SS
From everything I've read....that's a bad move with the stock SS pump. I'll be stunned if you have enough fuel. People here say that even the ZL1 pump with ADM FPCM can't deliver on E85. Do you even have a BAP?
I think you'll end up with bits and pieces of your piston and rods laying in your oil pan if you do this.
cc-rider is offline   Reply With Quote
Old 03-26-2016, 01:43 AM   #4
10 Silver Bullet
10 Silver Bullet's Avatar
Drives: 2010 Silver SS2
I have a ZL1 fuel pump for sale
10 Silver Bullet is offline   Reply With Quote
Old 03-26-2016, 02:56 AM   #5
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Still not enough
ttshovel is offline   Reply With Quote
Old 03-26-2016, 02:57 AM   #6
ttshovel
ttshovel's Avatar
+1
You need a dual pump setup. Ideally a dual 450 setup
Old 03-26-2016, 12:26 PM   #7
CobraR
Drives: 2010 2SS
to run E85, you will have to supply at least 25% more E85 than pump gas at your current power level. You are already at the boarder for a SS pump with a BAP on pump. Time to upgrade the fuel system if you really want E85. Not worth destroying an engine for.
Other question is, are you still on a 6 rib belt? Because I would be surprised if you will hit 11 psi on a stock belt setup.
CobraR is offline   Reply With Quote
Old 03-26-2016, 08:32 PM   #8
sprayedv
Drives: 2012 CTS-V, 2010 Camaro SS
You will end up blown up.
2012 CTS-V: Cosmetic Chute.
sprayedv is offline   Reply With Quote
Old 03-28-2016, 03:36 AM   #9
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Like the others have said, you'll blow it up. Whats your current fuel pressure at WOT, on your current setup? Are you even running a boost a pump?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-28-2016, 10:33 PM   #10
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
600whp on the stock pump?
Now you're upping the boost and switching to e85?
On the stock effing pump?
This won't end well.
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
Old 03-28-2016, 10:52 PM   #11
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
This lol. Camaro5 never fails to amaze me with the ridiculous posts.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 04-12-2016, 09:09 PM   #12
CALLAWAY11
CALLAWAY11's Avatar
Old 04-13-2016, 11:54 AM   #13
cc-rider
That's good to hear. Stock fuel pump would have blown your engine for sure.
HP guess...seing that you were 600ish before the E85...maybe 700? I haven't done E85 yet or researching it that much. But I'm sure some of the corn vets could give you a pretty close guess.
Old 04-13-2016, 01:26 PM   #14
CALLAWAY11
CALLAWAY11's Avatar
That would be awesome to be in the 700's. I'm hoping for that too.
