![]() Drives: 2010 Camaro SS Join Date: Jan 2015
Easiest way to remove plasti dip?
Tried to plasti dip my Camaro emblems and not sure if it was too thick, or too cold when I applied, but regardless they came out less than to be desired. Using goo gone now which works except it's still sticking in the crevices behind the emblem and inside the letters . Any advice?
2010 Camaro SS Inferno Orange 6-Speed . Edelbrock E Force Supercharger, Volant Cold Air Intake, Magnaflow Exhaust, River City Creations Emblems, Oracle ghosted LED markers, SLP faded gills, ...531 rwhp, 490 rwtq
![]() Drives: 2010 SS Join Date: May 2014
wd40
![]() Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
Try using a toothpick to get in the corners and crevices.
U.S. Army Retired |
Daily Driver 24/7 365
Drives: '15 CRT 2SS/RS/1LE Join Date: Jul 2015
Q tips dunked in some goofoff will work well for inside those pesky letters.
NPP Fuse Pull, Z28 CAI =
![]() Previous Rides: 2005 Magnum R/T A5 CAI, Cat-Back 2014 RRM Camaro 1LT/RS A6/NPP CAI Follow Me On Instagram! |
I did, must be too thick in there as its being difficult but good idea.
#6 | |
Thanks, not a bad idea
#7 |
Banned
Drives: Camaro Join Date: Mar 2013
Goof off may eat the adhesive holding the emblem on.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
2011 2SS/RS built 8/24/10
#9 |
i figure next step is just take the emblems off and leave it off as I like that look too...
#10 | |
If you ever want to put them on, you can buy new emblems with the adhesive attached already, and just dip them before putting them on the car.
#11 |
another good point. I wanted to order the black ones i found on phasetek but read they are not same size so decided not to. Any tips on easy removal of those emblems?
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I removed mine by heating them up with a heat gun (careful of setting as you can burn the paint) then sawed through the adhesive with fishing line. 3M adhesive remover to get residue off. I guess you could also use goo-b-gone.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS M6 Join Date: Nov 2014
Plasti-Dip
#14 | |
![]() Then used goo gone for the goo.
