Old 03-30-2016, 04:48 PM   #1
jeff657756
Drives: 2014 SS 1LE
Taillight Tint
I have the Big Worm Graphix Smoked (medium) tint on my '14 taillights (RS). i didnt like it at first because I left some bubbles in them after the install. After a couple days they settled out and now they are only slightly visible if you look hard enough. I also bought the xpel taillight and side marker kit from phastek. It seems much thicker than the big workm kit. my question is, does anyone have experience with the xpel tailight tint kit? Wondering if its darker/lighter or easier harder to install than the big worm kit.
jeff657756 is offline   Reply With Quote
Old 03-30-2016, 08:07 PM   #2
wrtowman
wrtowman's Avatar
Drives: 2011 Camaro 1SS
I had the Xpel kit for every light on the car. The cut was terrible on every piece. Check it out before you use any pieces and send it back if it isnt right. The side marker pieces were the only usable parts and even they left a lot to be desired. The tails were the worst. To be fair, it isnt Phasteks fault and they offered an RMA. Also, the pieces are top quality. Just didnt fit proper.
wrtowman is offline   Reply With Quote
Old 03-31-2016, 06:01 PM   #3
jeff657756
Drives: 2014 SS 1LE
That's why in wondering if it is even worth taking my big worm taillight tint off. Might not be worth the hassle
Old 04-02-2016, 09:38 AM   #4
Mikelofty
Drives: 2014 1LT Summit White
Did mine yesterday...
Mikelofty is offline   Reply With Quote
Old 04-02-2016, 11:36 AM   #5
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
