Old 03-31-2016, 02:21 AM   #1
fmherrera84
Drives: red 2014
Single or dual clutch? That is the question.
Hello all,
I have a 2014 Camaro with a V6. I am having work done on second gear and looking to have the clutch replaced.
Do I put in a single stage or dual stage clutch?
What are the benefits?
What are the is disadvantages?
Will it help my second gear stop slipping when I go into it with high RPM's?
What do you recommend I buy and brand?
fmherrera84 is offline   Reply With Quote
Old 03-31-2016, 06:44 AM   #2
derek1387
Drives: 2015 1LS Red V6
Where are you finding clutch options...nobody makes one for the 14-15 at the moment. Unless that has changed in the last month or so.
I am working with Steve at Monster Clutch on developing a clutch for the 14-15, but nothing is final yet.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 03-31-2016, 09:56 AM   #3
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
Sub'd
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
Shawno72 is offline   Reply With Quote
Old 03-31-2016, 07:39 PM   #4
fmherrera84
Drives: red 2014
No i have not done any research yet. This was my first place. So the only thing available is the factory clutch at this time?
clutch, dual disc, lfx, single disk
