![]() Drives: Camaro ss 1le Join Date: Jan 2014
Time for upgrade thanx Andy at Adm Performance
Hi y'all
It's been almost a year since i pull the trigger and did a Adm Lsa conversion, Andy did the installation, and what a job he did, i put about 21k on the Lsa setup and never had any problem with it i end up doing Btr stage 1 cam and 85lb injectors and we were able to make 655rwhp and 604 lbft and i was more then happy with the results, so after awhile i got used to that power and i wanted more as all of us in here we always want more. After talking to Andy about going big he recommended me to go with LSX376 so I pulled the trigger and went with that engine, today I dropped off the car at Andy at ADM Performance and i am super excited, our goal is to hit 700 rwhp, i am still using the same setup but different cam and pulleys. I will keep you guys posted Last edited by ilir14; 04-03-2016 at 10:58 AM. |
'It's an experiment'
Awesome! B15 engine?
Gonna be great! -Don
747 RWHP 794 RWTQ
Nice!
Can't wait to see this. My future engine is a b15... -Don
747 RWHP 794 RWTQ
Drives: Anything I want Join Date: Oct 2008
Good solid build here
This will be a good solid build none the less.
Specs - LSX B8 engine BTR Stage 3 PD Cam BTR Valvesprings KenneBell Boosta pump ADM 8 rib conversion with Stock LSA Balancer 2.38" Pulley Stainless Power Headers 17/8 Magnaflow X Pipe muffler - Keep this 1LE quiet ADM Dual Pass Heat exchanger Adding the above will make this car a whole new animal. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Cool build and reliable.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
#7 |
Quick update, got the engine at Andy shop hopefully by the end of this week he'll be able to install it can't wait to see this thing
#8 |
![]() Drives: 2017 SS 6sp Join Date: Jun 2014
#9 |
Difference
The B8 uses ls3 crank and rods as well as ls3 heads.
The B15 uses lsa crank and rods as well as 6 bolt heads. The B15 engine requires an upgraded clutch due to its Crank Flywheel bolt pattern. When you use a B15 in an AUTO car you must run a CTSV/ZL1 flexplate. |
#10 |
![]() Drives: 2018 ZL1 A10 Join Date: Mar 2013
Andy did the B15 swap for me. Its a blast to drive. You'll be really happy with your results.
Work in progress
#11 |
The car
The car was very impressive before,I can only imagine what it is going to be like now.
#12 |
![]() ![]() Drives: 2013 Camaro ZL1 Join Date: Nov 2012
I'm just as excited about my car being at ADM! He's a 1000 miles away from me but I still won't take it anywhere else.
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp |
#13 |
Update
Going back in pic and more
#14 |
Oh man, that is making me rethink the B15 now! Can't wait for the #s...
-Don
747 RWHP 794 RWTQ
