![]() Drives: 2010 Camaro 2SS/RS Join Date: Apr 2010
Eaton differential question
Morning every one. Has any one used the Eaton true trac in a L99 car for strip and road course use?
How does the Eaton install affect traction control and stabilitrac or do they need to be turned off?
2010 2SS/RS L99 CAI intake Stainless Works headers and Hi-flow cats CORSA cat back exhaust livernois motorsports dyno tune VMAX throttle body ELITE catch can GM clean side catch can 2014 lca BMR rear toe links PEDDERS Supercar suspension PEDDERS poly subframe bushings JPSS BLACK MAGIC rear sway bar DSS 1000 hp axles 1LE wheels Michelin 285/35 tires CTS-V front brake upgrade fuel rail flip heater hose relocation
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
M6, no issues on road courses or drag racing.
No stability/traction control issues either. Sent from my iPhone using Tapatalk
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Tim aka hrd wrk has L99 with Eaton, maybe he'll see this post. He has done autoX.
I have the Eaton, but only drag race.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
2010SSRSM6 , Pro Stock John Thanks for the response. I am really thinking it could be helpful to go the Eaton route.
I will try to ask hrd wrk or his input.
Writer
I had to, I broke my spider gears.
PROJECT HEAVY CHEVY
#6 |
Pro Stock John I may have done some damage to differential also. Had a cv joint go on the drivers side axle. The one at the wheel flange.
DSS quickly sent a RMA to send the axle to them. On the way to them now. Will know more in a couple of days. Differential cover has to come off to check it out. May replace stock differential with Eaton unit while it's opened up. Rodgers Chevrolet will be doing the work.
#7 |
Pro Stock John do you have a different user name for hrd wrk. Doing a search from main forum comes back as invalid user.
#8 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
#9 |
hrpiii Thanks for the info.
#10 |
HARD WORKING PATRIOT
Drives: 2011 CAMARO 2SS RS-AUTO Join Date: Oct 2010
Feel like im at a bar and my name is Norm....hahaha.
Yes I drag race (primary) and Autocross as fill in with local guys. yes i got an Eaton to permanently resolve bad clutches and one wheel peel. All nannies off for drag. All nannies off for autox , except when there are walls close to running lane. Fish tailed a little close to one at 82mph. I keep the stabilitrac on for those or if there's alot of sand on the track.never have had issues. I understand your concern. I had the same too before i bought mine. I asked a ton of people on the road racing and no one said they had problems. Get the LPW cover and a gear. Enjoy. Tim
Long time avid daily reader -thanks to all for your helpful threads!
Bolt ons, Stock Torq Converter - 11.810 & 116.21 |
#11 |
HRD_WRK Thanks for the info. I will know more in a couple of days on the possible differential damage. The axles will be here today. Thank god, Camaro withdrawal sucks:-)
#12 | |
Know that feeling. I broke my motor in October and don't get it back until next week.......
