![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS IOM/IOM #3625 Join Date: Jun 2008
Anyone else having problems keeping their tire pressure at 36psi/248kpa? Since June I have had to top the tire pressure up every couple of weeks. Check them while cold, top them up to 36 psi and within a week or so the monitor on the DIC says they are now down ever so slightly (2lbs on one tire, 3lbs on another, etc.), not all are and it is never the same tire(s) that are below the 36 psi.
Has anyone had nitrogen added to their tire air and does it really help? This is more an annoyance than anything else, but with the price of the P-Zero's being what they are, any unnecessary wear is costing money.
666 EVIL RWHP BUILT AND TUNED BY SHIFTED PERCEPTIONS INC.(SPi)
416 Forged Stroker, E-Force Supercharger, Blower Cam, Rotofab CAI, Stainless Works 2" LT Headers and 3" Exhaust, LPE ZR1 Twin Disc Clutch, DSS 1400 HP Axles, Pfadt Performance Kit Stage 3. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Angry Dorothy II 2016 2SS Join Date: Aug 2009
yes . I kept getting ON STAR emails in june and aug that the pressure was ok eventhough it was anywhere from 224 to 242. Then when I went to the dealer two months after buying the car they said there was only 30lbs in each tire so they filled it up to 36. Then last week , ONSTAR again shows less than 248 (238-244) but again gives the green checkmark as if its ok. Left rear is lowest with 238 right now.Guess nitrogen is the key. |
#3 | |
This after I had just checked and filled each to the recommended 248kpa on Sunday the 20th.
![]() Drives: Camaro 2LT RS Join Date: Jul 2009
There was a thread about this somewhere on the forum where one of the sensors was not working correctly. The conclusion from that thread was that a manual check (with another gauge) was probably the best indicator of air pressure.
Air is already made up of mostly Nitrogen (about 70%). I have heard that Nitrogen in tires does not make that much of a difference. |
![]() ![]() ![]() ![]() Drives: 1SSRS RY L99 Join Date: Aug 2009
No tire will ever be 100% air-tight. Every tire will leak about 2 psi a month. Air molecules will actually percolate through the rubber. Some will leak faster, others slower. When you start to lose 5 psi in a couple of weeks, then you have a problem.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: CHEVROLET Join Date: Jul 2008
I was having the same issue, but I was monitoring them on a weekly basis. When I checked them, with my own tire pressure gauge, it was giving a proper inflated reading. I noticed that when I checked the pressure reading, through the car, the metric reading was indicating they were low. However, when I would set the reading to imperial, it would show that the tires were 2 pounds over the inflation rate
![]() I just trust my own tire pressure gauge, and not a computer, because I also got those on-star monthly reports indicating the opposite. I know of other people, who bought cars in the past with tire sensor readers, and they too indicated false readings. MY ADVICE IS ALWAYS HAVE A HIGH QUALITY TIRE PRESSURE GAUGE WITH YOU! PLEASE DON'T USE THOSE $5 POP-UP STICK GAUGES, INVEST IN A GOOD ONE PREFERRABLY THE DIAL TYPE, EVEN THE DIGITAL CAN GIVE FALSE READINGS. Last edited by SQUALO; 10-15-2009 at 12:43 PM. |
#7 |
Psycho on day pass
Drives: 2010 yellow 1ss m6 -GM tech Join Date: Apr 2009
When using conventional air, the readings will always jump a few psi. If one side of your car is warmed up by the sun more compared to the other, naturally the air pressure on the warm side will go up.
If using nitrogen, this problem shouldn't really occur because there is no moisture in the element to fluctuate with sun or hot cold inflation issues. Search the use of nitrogen in tires and it will explain it better than I could this morning. |
#8 |
![]() Drives: 2010 BumbleBee ready to go now Join Date: Jan 2009
Has anyone used nitrogen yet ??? Our tire shop just got the compressor installed and wants me to do it ??? Not sure, what does everyone think ?? :-)
#9 |
OH CANADA!
Drives: 2011 RAM 1500 LARAMIE Join Date: Mar 2009
i haven't had any problems with this. haven't touched my tire pressures since i got her. that was back in July...
Had to trade in the Camaro for a truck :(, but hopefully I can join the Camaro family again one day ![]() |
#10 |
Banned
Drives: A Black Car Join Date: Mar 2009
I don't know why shops are pushing Nitrogen inflation. The air you breathe is mostly Nitrogen. And how do I check if there really IS 100% Nitrogen in my tires?
I've noticed the slow leak. Make sure the air valves are tight. |
#11 | |
Banned
Hot gases expand and create high pressure within an enclosure. Cooled gasses will compress and create low pressure within an enclosure. Check your pressure on a cool morning. Fill your tires to 36psi. Ensure that the valves are tight. |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS IOM - A.K.A. DA ;) Join Date: Jan 2009
I think RickRay has Nitrogen. I haven't noticed any loss parse. But I check regularly and adjust as necessary. Try to do while car is cool and in the garage as running temps, direct sunlight etc affects the pressures and results in uneven inflation. Dito on the high quality gauge. Don't forget that pressures will change as the season changes too. As it gets colder you'll need to add more air to maintain proper pressure.
On a side note, I wonder what will happen to the silly monthy OnStar emails when I store her for the winter and disconnect the battery ground strap? (sorry for the jacked thread)
"BBOMG - More than just a car show.... It's an experience!" |
#13 |
Man, this nitrogen has got to be the biggest gimic! Unless you are driving a NASCAR at 200 mph, you don't need nitrogen. Your tires aren't going to expand enough due to heat to make using nitrogen worth it. I do work in a dealership, for heavy trucks. We had a large fleet that used nitrogen on a bunch of test trucks and trailers and saw no difference in tire life or pressure retainabilty. Due to the added hassle and cost of needing special compressors, or nitrogen bottles, they canceled it. Don't waste your money!
#14 |
![]() Drives: 1987 Camaro LT, 2010 Camaro 2SS Join Date: Aug 2009
With colder weather coming pressure flucuation will happen almost daily. for every 10 degree drop in temp you will lose a 1 lb of air. nitrogen is over rated anyways it still loses pressure just at much slower rate.
| tire pressure issues | boostedyards86 | Dragstrip and Launch Techniques Discussion | 11 | 08-23-2009 08:03 PM |
| Tire Pressure Monitoring | Dentyneice | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 08-14-2009 07:42 AM |
| How does onstar know what tire pressure I have? | FLYNNZL1 | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 08-09-2009 03:11 PM |
| Resetting TPMS Tire Pressure System | jvmax | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 07-10-2009 01:37 AM |
| Tire Pressure | toehead93 | Dragstrip and Launch Techniques Discussion | 4 | 06-09-2009 01:24 PM |
