![]() Drives: 2012 Victory Red Camaro 2SS/RS M6 Join Date: Jun 2014
Iphone to USB error message?
Almost every time i connect my iPhone to my USB connection it will charge but not use my music stating something along the lines of "device not supported". Is this a quick fix or does it have to do with my phone? Its a iPhone 6 on 9.2.1 if that matters. Thanks all.
2012 Victory Red 2SS/RS: Roto-Fab CAI, Long Tubes, HF Cats. Corsa Catback, Hurst Short Throw, LSA Supercharged, ADM 3-belt Conversion, LS3 TB, Reinforced Brick, 2.55 Griptec upper, ATI Super Damper, 10% lower OD, 1000cc FIC Injectors, ZL1 Fuel pump and 305 MT ET S/S. 575/599
Did it work previously versions of iOS when you plugged your phone in?
it worked intermittently between the upgrades but probably not in the last couple at all.
Make sure it's a real iPhone wire , also close your music app sometimes when that happens to me that works good luck
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
![]() Drives: 2017 1LE SS Join Date: May 2014
Had that with 9.2 but it went away for me with 9.3
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
