Old 04-08-2016, 02:17 AM   #1
avido
Drives: camaro ss\rs
booooooost
it has been a year since i have the cam on the car and i'm pretty happy. it's a whole new car ad sounds really mean. As most of as know it's easy to get the hang of the power so i'm looking for a supercharger. On the market a lot of choice and types of it.What actually keep my attention is the lsa conversion from Adm. It seems pretty straight forwad mounting process andit delivers a good amount of power. Dos anyone has a suggestion for me? just keep in mind the car is a daily and i use it for 50 miles in the traffic so I can drive with a 8500hp
as always thanks for your help
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
avido is offline   Reply With Quote
Old 04-08-2016, 10:45 AM   #2
hammdo
'It's an experiment'
hammdo's Avatar
The Meziere is the only thing I'm not sure about since its bolt up may be different.
25% under drive pulley is out as it affects the blower spin. Cam specs would need to be reviewed just to be sure...
LSA kit is very reliable and great street manners. I love mine. Easy enough to install and, GM factory parts. Get it while you can, GM is aware of the kit ;o) and has been changing the pricing of the parts recently...
Looks awesome too...
-Don
747 RWHP 794 RWTQ
Old 04-08-2016, 12:10 PM   #3
ilir14
ilir14's Avatar
Drives: Camaro ss 1le
Andy did my installation a year ago and these blowers make a ton of power for its size i love mine,and i am sure you're going to love yours mine also is a DD, i put about 21k on the set up and talking about reliable ask me
ilir14 is offline   Reply With Quote
Old 04-08-2016, 02:03 PM   #4
avido
And what about the clutch? It can handle the extra power? I know the cam is not the best for a blower but I'll change in a second time. I thought when I put the night fury it was enough but it's no tho.as soon as you get the hang of the power you want a step further
Same story for the pulley. I'll put the stock one and when I'll change the cam I'm a change it too with the overdrive. Unless they don't do just a pulley upgrade since it is removable
Old 04-08-2016, 02:25 PM   #5
ilir14
ilir14's Avatar
i had no problem with the clutch never slipped but thats just me, i will recommend do the cam now, pulleys you can change easy
Old 04-08-2016, 04:58 PM   #6
hammdo
hammdo's Avatar
I have a VVT SS1 NA cam and no issues with that. It's more about radical cams really...
Clutch should be fine for your expected power numbers...
-Don
747 RWHP 794 RWTQ
Old 04-09-2016, 04:22 AM   #7
avido
That 's pretty good,I was afraid for the clutch.
There is something else I need?
Old 04-09-2016, 11:38 AM   #8
ilir14
ilir14's Avatar
Yes, New pair of tires
Old 04-09-2016, 12:05 PM   #9
avido
So the lsa conversion has everything I need to unleash the beast
Old 04-09-2016, 12:09 PM   #10
gennro
Drives: 2011 Black 2SS
Go ahead and do the ADM 2.75 supercharger pulley, ZL1 fuel pump, and ADM FPCM.
gennro is offline   Reply With Quote
Old 04-09-2016, 12:52 PM   #11
avido
Shoulden't be the zl1 pump in the 2014 camaro?
Old 04-09-2016, 01:41 PM   #12
hammdo
hammdo's Avatar
1LE has it. You can get by with the SS, but, if you really want to go further consider the ZL1 pump and FPCM from ADM...
-Don
747 RWHP 794 RWTQ
Old 04-09-2016, 05:46 PM   #13
avido
I'll check it out. What bother me is removing the tank. Why don't they think about a window under the seats...
Old 04-09-2016, 07:26 PM   #14
hammdo
hammdo's Avatar
If you take out the front 2 bolts in the rear cradle out and lower the front part of the rear cradle, you should have enough room to drop the tank once you have eveything off.
-Don
747 RWHP 794 RWTQ
