Old 04-09-2016, 08:53 PM   #1
kuvanno
kuvanno's Avatar
Drives: 2012 yellow
Unhappy Stabilitytrak, a very weird issue
Hi everyone, my thread is very weird, today I was driving my camaro and when I stopped at a light, the car started to shake, then the check engine light turned on and appeared a message: stabilitytrak. That was for about 30 seconds, then the car stopped shaking, the check engine light turned off and the message disappeared. I continued driving and when I brake, sometimes it was like the car was pushing me. I finished my trip and when I started my car again, no more issues or something else, everything was perfect. Somebody knows something about that???
Almost forget to write what kind of car I own. It's a 2012 Chevy camaro LS and has 25.000 miles.
Thank you all
Last edited by kuvanno; 04-09-2016 at 09:07 PM. Reason: Forgot to say what car is mine
kuvanno is offline   Reply With Quote
Old 04-10-2016, 06:37 AM   #2
fhrex
Drives: 2011 Camaro 2LT/RS
The car shaking may have been a misfire, which triggered the check engine light. When the check engine light illuminates, the stabilitrak system goes into a default mode, which gives that message on the DIC. The only way to find out what was actually going on is to have a diagnostic run.
fhrex is offline   Reply With Quote
Old 04-10-2016, 07:45 AM   #3
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Take it to an Auto Parts store, they have code readers. Misfires are a common in the V-6. It's most likely a coil pack, if it goes away that's fine. When it continues one of the coil packs has gone bad. AMAZON.com for about $25, $80 at the Stealership, I keep a spare in my trunk.
Eddiefuzz is offline   Reply With Quote
Old 04-10-2016, 08:46 AM   #4
pilldoctor
pilldoctor's Avatar
Drives: 2013 Summit White 2LT RS
This exact thing has happened to me twice in the last 4 months. After the first time, I took it to advance auto to scan and they found no codes. Still under warranty so took it to dealer. They did a scan also and no codes either.
pilldoctor is offline   Reply With Quote
shake, stabilitrack
