Old 04-10-2016, 01:36 AM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Soooo...Nitrous..Whats good?
Never played with it. Seen it in action. Whats a good overall kit for a DD 1Le with the occasional spirited driving?
RupertPupkin is offline   Reply With Quote
Old 04-10-2016, 02:21 AM   #2
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Ask nitrous outlet. Should cost 1000$ for a great street kit up to 175-200hp with everything you need. Many brands outhere.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 04-10-2016, 08:02 AM   #3
RupertPupkin
I saw zex, company you mentioned.. etc.. etc.
Old 04-10-2016, 08:04 AM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
They all make good kits now, just make sure you get the pressure safety switches. Also check this out for the tune, you can flip a switch and have a nitrous tune.
zz430camaro is offline   Reply With Quote
Old 04-10-2016, 09:15 AM   #5
flyer08
Drives: 2010 2SS/RS
1000 is a bit cheap if he wants to do it right
flyer08 is offline   Reply With Quote
Old 04-10-2016, 09:31 AM   #6
TXsilvy
Drives: camaro
The guys at nitrous outlet are awesome. Theyve never given me an excuse to go elsewhere. Look up the free nitrous resistor mod before spending money on a retard box. Both work great, but one of them only costs about 20cents
1969 pro street
heads/cam/blown/meth 408 LS
TXsilvy is offline   Reply With Quote
Old 04-10-2016, 11:39 AM   #7
RupertPupkin
Im assuming I need injectors, and fuel pump?
Old 04-10-2016, 12:01 PM   #8
zz430camaro
Drives: 2015 1LE
It all depends on how much power you want to make. Just call the companies and tell them what you want to do and they will know what you need to do it correctly.
Old 04-10-2016, 01:35 PM   #9
flyer08
Drives: 2010 2SS/RS
Get a dedicated fuel cell and you,won't need to worry about injectors and fuel pump. Be cheaper in long run anyways.
Old 04-10-2016, 01:50 PM   #10
TXsilvy
Drives: camaro
No need for extra injector with a wet kit. Im not sure what a stock pump can support.
1969 pro street
Old 04-10-2016, 07:59 PM   #11
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
This^. The more you cheap out the less convenient and less safe it will be to use. On a 4th gen f-body or other cheaper/older car, sure. But on a newer 30-40k+ car I'd want it to be safer, cleaner looking, and more convenient to use. I love having stuff like a remote bottle opener and other crap I don't really need but is really nice to have.
If you are stock engine then you can do a 150 on the stock fuel system (100 shot max if youre cammed). Any more than that and a standalone fuel cell is the way to go.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 04-10-2016, 11:34 PM   #12
RupertPupkin
Stock engine. The only thing itll have would be intake/headers. Any brands you guys prefer.
Old 04-11-2016, 12:13 AM   #13
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Well I dont see how you can get past 1000 so much for a street kit. Break it down for me pls. Had mine under 1000$
-kit with 300hp nozzle
-Bottle heater and rack
-FPSS
-Spark plugs
-timing tuner
-pressure gauge on the bottle.
-wide band or spark plug tuning
-nitrous purge (no need)
More money is for fancy setup, not safer.
13' 1LE
Old 04-11-2016, 09:02 AM   #14
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Ran Nitrous back before many were probably born on this Board. Yeah old here lol. Open Bottle Push button and hope it held together lol Things have come along long way which is a great thing.
Comparing Apples to Oranges here because this is a system built for 1/2 Mile runs on a built for Nitrous 416 Went with Dual Bottle Setup with all the Safety Backups, Bells and Whistles. This will just show the prices of some of those Needed Items, Safety Features Bells and Whistles. Yeah Street Kits can be had under $1000 but OP don't forget to add in price of labor( if not installing yourself), retuning, filling bottle.
Nitrous Outlet LSX Plate System
-10 lb. Bottle
799.99 799.99T
Nitrous Outlet 10lb Bottle 197.99 197.99T
Nitrous Outlet Luminescent Pressure Gauge 31.99 31.99T
Nitrous Outlet Y-Block w/ Lines & Fittings 99.99 99.99T
Nitrous Outlet Stage III Accessory Pack -6 530.58 530.58T
Nitrous Outlet Camaro Center Console Switch Panel 99.99 99.99T
Lingenfelter LNC Two Step Launcher With Built In Timing Retard 334.95 334.95T
NOS Nitrous Launch Controller 444.99 444.99T
Nitrous Outlet 2 Gallon Dedicated Fuel System 949.99 949.99T
Misc / Wires / Relays / AN Lines / Fittings 120.00 120.00T
Fill Nitrous Bottle (5 lbs for Dyno plus 10lbs fill) 25 5.00 125.00T
NGK Non Projected 8 Spark Plugs 8 3.99 31.92T
zz430camaro Are they making it for the LSx yet? Only found info on it for the Mustang.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
