Old 04-11-2016, 12:16 PM   #1
Buckley12
Drives: 2013 zl1
Heat exchanger/catch can?
Is a heat exchanger and catch can necessary or just wanted? The heat exchanger I can see more then the catch can. It's a silly question it its the first time getting into these power ranges where these things now come into play.
Buckley12 is offline   Reply With Quote
Old 04-11-2016, 01:16 PM   #2
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
Anything you can do to keep the car running cooler (especially the supercharger) is a good thing. I have a catch can, but it isn't necessarily needed. More of a preventative maintenance thing.
jayno20 is offline   Reply With Quote
Old 04-11-2016, 05:12 PM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Both are a good idea.
The catch can is augured back and forth but it helps keep the oil blow by from creating deposits on your cylinder heads and intake.
You can find 10,000 topics on C5 about it.
The HX does help as I have both the RD HX and D3 extra coolant tank and I track my car.
Mods:
Old 04-11-2016, 06:34 PM   #4
Buckley12
Drives: 2013 zl1
Okay, I'll have to start looking into them. Thank you
Old 04-12-2016, 01:10 PM   #5
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Let us know and we can guide you through the absolute best solution for your car.
Do it once, do it right, Elite Engineering USA
Elite Engineering is offline   Reply With Quote
