Old 04-11-2016, 03:29 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
2010 camaro needs rear brembo conversion for FE4 setup?
I was looking into doing the fe4 switch on my 2010 2Lt. But from what I see, I need to swap out rear brake calipers. I'm curious as to why it's necessary?
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 04-11-2016, 04:05 PM   #2
Mike_G
Drives: 2010 2SS/RS
sway bar can come into contact with the guides for the V6 calipers as the pads wear down.
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs....
Use to have
2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's
Mike_G is offline   Reply With Quote
Old 04-11-2016, 06:39 PM   #3
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
This is exclusively a V6 problem. The SS's don't have to swap rear brakes as they have the same calipers as the ZL1 and 1LE.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 04-11-2016, 08:00 PM   #4
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
You need this rear sway bar John- compatible with stock V6 brakes and so much better than stock! http://www.jpssonline.com/
The factory FE4 bar will contact the rear banjo fitting on your brakes as they wear and bad things can result.
Also if you haven't corrected the rear subframe bushings, take care of that as well (inserts are fine and a easy install with stock/bolt-on power levels) and you are good to go.
Makes a new car out of the 2010's!
