Old 04-12-2016, 08:58 AM   #1
atiprocharger
atiprocharger's Avatar
Drives: Black 2018 Camaro ZL1 auto
What meth kit do you use?
Hi All! I was thinking of getting a meth kit for my current setup. Looking for any recommendations, experiences, etc for users that have a slp tvs 2300.....or similar. Mine is a daily driver.
Thank you!
2018 ZL1 A10 with PTB, ROTOFAB, Pulley and tune from
Vengeance. 607 rwhp/647 rwtq
atiprocharger is offline   Reply With Quote
Old 04-12-2016, 11:46 AM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Alky control here. Julio is the man, when it comes to customer support and knowledge.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 04-12-2016, 07:57 PM   #3
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
Alky FTW!
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 04-13-2016, 03:56 AM   #4
Glushenij
Glushenij's Avatar
Drives: 2014 Camaro 2SS 1LE
Aem integrated for Camaro from AGP( it's only 1 gallon but enough for me) if u do a lot racing u may want go different brand
AGP TT 807whp 811wtq 13.46psi E85+methanol
Glushenij is offline   Reply With Quote
Old 04-13-2016, 08:09 AM   #5
SingleT
Drives: 2015 2SS
Any more info on agp integrated kit ?
SingleT is offline   Reply With Quote
Old 04-13-2016, 08:23 AM   #6
Unreal
Drives: 2006 Z06
Part of their turbo kit as an option. Comes with tank/pump/controller/lines. Kit is already preplumbed for meth (unlike other kits) so just undo the plugs and plug their system in.
If you don't have an AGP turbo kit, then you would have to work with them to see about doing a custom setup for a different application. They designed/made a kit for their setups.
Nick
Corvette Z06 -1200ish rwhp
Old 04-13-2016, 09:36 AM   #7
SingleT
Drives: 2015 2SS
I'm getting ready to install my dual nozzle AEM kit on my single turbo car but was curious what they did or if they did anything special for this chassis specifically.
Old 04-13-2016, 09:42 AM   #8
Unreal
Drives: 2006 Z06
They do custom lines, mounts, pump location brackets, tank, etc. But it is all setup around their kit.
Nick
Old 04-13-2016, 09:43 AM   #9
SingleT
Drives: 2015 2SS
Sounds like another reason the AGP kit is second to none.
Old 04-14-2016, 10:05 PM   #10
pwr trpn
Drives: 2011 Camara SS
Snow w/boost juice. this is on a DD.
S/C 427ci LSX 2011 SS
pwr trpn is offline   Reply With Quote
Old 04-15-2016, 12:51 PM   #11
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Snow performance progressive kit. Ran 100% meth for over a year with no problems. Sold the kit and switched to nitrous.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 04-16-2016, 03:48 PM   #12
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Any AIS users here?
Unavowed is offline   Reply With Quote
Old 04-17-2016, 04:51 PM   #13
Detoxx03
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Detoxx03's Avatar
Drives: 2008 Corvette
Alky Control
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 04-17-2016, 09:33 PM   #14
ToddB
Drives: 2011 2SS Convertible Supercharged
Ally control
ToddB is offline   Reply With Quote
