Old 04-13-2016, 12:22 PM   #1
mrWizard
mrWizard's Avatar
Drives: 2010 Camaro 2SS/RS M6
"Vacuum Robbing" Camshaft and vacuum reservoirs/pumps
So, I noticed that 2010 SS doesn't have the same braking performance it used to, after having a camshaft installed. I can stand on the pedal and the tires don't squeal and the ABS doesn't kick in, which cause the car to take some time to stop in an emergency situation. I measured the vacuum from the intake manifold to the booster at ~8-10 in.
I've tested my booster to make sure it is air tight with no leaks, it is. I also checked the check valve, that is working fine. So does anyone have any experience with this? Am I going to need to install a reservoir or pump to increase my vacuum pressure? Or can tuning the vehicle differently increase my vacuum pressure from the booster?
Thanks in advance.
mrWizard is offline   Reply With Quote
Old 04-13-2016, 01:18 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I had the issue years ago a 71 C10 I had, I put in a big ole narly cam and all but lost my power brakes, but it was a automatic and I put a stall converter in it it helped a little, i think it has something to do with the overlap. I think a vacuum tank would help just dont know how to plumb it in.
Orange Krush II
Old 04-13-2016, 01:47 PM   #3
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
If I remember correctly, once cam duration reaches a certain point you begin to loose engine vacuum. This of course begins to affect anything that operates off of vacuum. Sorry I can not tell you at what point that is though. I'm sure someone will chime in with more knowledge.
HOJO is offline   Reply With Quote
Old 04-13-2016, 01:59 PM   #4
mrWizard
mrWizard's Avatar
Hmmm, sounds like that would make sense. For anyone else that could chime in about this, here are the specs on my cam:
231/243 @.05 .617/.623 113
Yeah the more I read, it seems like the vacuum tank is the way to go. Here is some info from one manufacturer on installation.
http://www.jegs.com/InstallationInst...70-99590-1.pdf
Old 04-13-2016, 02:09 PM   #5
CamaroSS sleeper
Drives: Sleeper_NOT
I'm on the same boat on this one...
Interested to know how people are dealing with this.
also mine been turbo, when I go into boost I loose all booster power.
so doing those cool in place burnouts is absolutely impossible.
going off of boost and hitting the breaks, like in an emergency!
there is brake lag about 1-2 seconds.. but it feels like an eternity..
CamaroSS sleeper is offline   Reply With Quote
Old 04-13-2016, 02:46 PM   #6
mrWizard
mrWizard's Avatar
I don't know too much about turbo setups, but as long as you are making some increasing vacuum while driving, the vacuum reservoir will hold it for when you go to brake. Should eliminate you having to wait for vacuum again. And they are relatively cheap. Around $40-60.
Old 04-13-2016, 04:19 PM   #7
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
An electric vacuum pump would help this.
JerTM is offline   Reply With Quote
Old 04-13-2016, 09:36 PM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
A cool in place burnout is done with a line lock kit..... You could read up on the effects of LSA with a article by comp cams.........
http://www.compcams.com/Pages/413/ca...ion-angle.aspx
Effect Of Changes In Cam Timing And Lobe Separation Angle
The following tables illustrate how variations in lobe separation angle and cam
timing will effect the behavior of the engine in which the camshaft is installed.
EFFECTS OF ALTERING CAMSHAFT TIMING
Advancing Retarding
Begins Intake Event Sooner Delays Intake Closing Event
Open Intake Valve Sooner Keeps Intake Valve Open Later
Builds More Low-End Torque Builds More High-RPM Power
Decrease Piston-Intake Valve Clearance Increase Piston-Intake Valve Clearance
Increase Piston-Exhaust Valve Clearance Decrease Piston-Exhaust Valve Clearance
EFFECTS OF CHANGING LOBE SEPERATION ANGLE (LSA)
Tighten (smaller LSA number) Widen (larger LSA number)
Moves Torque to Lower RPM Raise Torque to Higher RPM
Increases Maximum Torque Reduces Maximum Torque
Narrow Power band Broadens Power Band
Builds Higher Cylinder Pressure Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock Decrease Chance of Engine Knock
Increase Cranking Compression Decrease Cranking Compression
Increase Effective Compression Decrease Effective Compression
Idle Vacuum is Reduced Idle Vacuum is Increased
Idle Quality Suffers Idle Quality Improves
Open Valve-Overlap Increases Open Valve-Overlap Decreases
Closed Valve-Overlap Increases Closed Valve-Overlap Decreases
Natural EGR Effect Increases Natural EGR Effect is Reduced
Decreases Piston-to-Valve Clearance Increases Piston-to-Valve Clearance
CAMSHAFT GEOGRAPHY AND LOBE FUNCTION
effects Of Changes In Cam Timing And Lobe Separation Angle
Advancing Retarding
Good Luck.
Old 04-30-2016, 01:02 PM   #9
mrWizard
mrWizard's Avatar
Little update:
Ended up putting in a vacuum canister. Holds vacuum and after revving it holds over 20 in and makes a difference when using the brakes. Not the best fix, but it works. Ended up mounting it to the positive battery terminal position after moving to over to the stock air intake filter bolt. It's the only area it would fit.
Went with this canister and vacuum gauge:
http://www.amazon.com/Mr-Gasket-3701...ilpage_o05_s00
http://www.amazon.com/1-1-Vacuum-Gau...ilpage_o00_s00
Old 05-01-2016, 07:24 AM   #10
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I lostbrake power too with my 231 236 on 111 lsa..might need this.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
brake booster, cam, camshaft, vacuum
