Old 04-13-2016, 01:33 PM   #1
ABMLS3
ABMLS3's Avatar
Drives: 2010 Aqua Blue Camaro 2SS/RS
estimated power i'll make?
Old setup:
IPS twin turbo kit
LS7 cam
CNC/ported ls3 heads
80# injectors
ZL1 fuel pump
Borla catback
made 611/576 on 8#of boost
New setup:
ECS novi1500
LS7 cam
80# injectors
ZL1 fuel pump
BAP
Borla catback
TSP 2" LT headers
looking to make 10# of boost
Getting my car dyno tuned tomorrow on the same dyno as with the twin turbos.
Any guesses on how much power i'll be making?
Power Source Performance Turbo Kit
416 C.I ,TH400
Instagram: TomTraube
COTW ABMLS3 Build Thread
ABMLS3 is offline   Reply With Quote
Old 04-13-2016, 01:49 PM   #2
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
645 rwhp fuel will be hold back
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 04-13-2016, 02:14 PM   #3
failshift
Banned
Originally Posted by ABMLS3 View Post
Old setup:
IPS twin turbo kit
LS7 cam
80# injectors
ZL1 fuel pump
Borla catback
New setup:
ECS novi1500
LS7 cam
80# injectors
ZL1 fuel pump
BAP
Borla catback
TSP 2" LT headers
Get ADM FPCM to help you from thinning out up top.
failshift is offline   Reply With Quote
Old 04-13-2016, 02:19 PM   #4
bct10985
Drives: 2010 2SS LS3, 2013 duramax
575rwhp
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 04-13-2016, 04:18 PM   #5
cc-rider
Drives: 2010 Camaro SS
Will be real interesting to see what you make. You may dyno a smaller number, but be faster in the 1/4 mile.
cc-rider is offline   Reply With Quote
Old 04-23-2016, 07:47 PM   #6
UNRIVALED SS
UNRIVALED SS's Avatar
Send a message via Yahoo to UNRIVALED SS
How much power?
SO. How much power did this combination make with that LS7 cam in it? I`m curious.
UNRIVALED SS is offline   Reply With Quote
Old 04-25-2016, 11:29 PM   #7
BradySS
Drives: 2010 Camaro 2SS
What made you switch from the twins to the Novi?
BradySS is offline   Reply With Quote
Old 04-26-2016, 01:14 AM   #8
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
575
2011 Victory Red 22/RS
Forged 418 Ls3 from Texas Speed, LSX heads from Texas Speed, Tick Turbo cam, Jakes/PCM/Billet 4l80e, 3200 Stall converter from Circle D, DSS 750 hp axles, DSS aluminum driveshaft, stock 3.23 gears, TSW Wheels Front 20x10 Rear 20x11.5, Fabberage Twin Turbo Supercharger Killer kit with Upgraded Turbos, Squash Dual fuel pump, Full BMR Suspension/bushings, Holly High Rise intake manifold, ID1300 Injectors, Megan Coilovers, PCM of NC plug and play trans kit. HP/TQ TBA
DaFisch is offline   Reply With Quote
Old 04-26-2016, 08:38 AM   #9
Unreal
Drives: 2006 Z06
He had an IPS kit and tons of trouble with it. It was probably more related to the kit and issues with parts failing and customer service than anything else.
Nick
Corvette Z06 -1200ish rwhp
Old 04-26-2016, 09:40 AM   #10
old motorhead
Drives: Maggie blown LS3 vette
650 if M6. 610 A6. Assuming Dynojet.
old motorhead is offline   Reply With Quote
Old 04-26-2016, 02:08 PM   #11
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
13 days out and no response. Must not have went as well as he was thinking. Hope it did for his sake.
HOJO is offline   Reply With Quote
Old 04-26-2016, 02:09 PM   #12
BradySS
Good to know. Thanks for the reply.
Old 04-27-2016, 01:31 PM   #13
ABMLS3
ABMLS3's Avatar
sorry guys i forgot about this post lol but i made 672/557 on 12#. This is a higher than normal reading dynojet btw... my brothers M6 SS made 435rwhp with only lt headers and cai on this same dyno for example
416 C.I ,TH400
Old 04-27-2016, 02:09 PM   #14
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
How do you like it? How do you like SC against turbo?
camarosspower is offline   Reply With Quote
