Old 04-14-2016, 04:37 PM   #1
bradywatt23
Drives: 2010 Camaro RS
AGP TT kit for higher milage SS
Im looking at possibly purchasing one of the AGP twin turbo kits for my SS. This car is my DD and has a little over 90k miles. Hopefully some of the knowledgeable members on here can tell me if that kit will be too hard on my older engine or not. Thanks!
bradywatt23 is offline   Reply With Quote
Old 04-14-2016, 05:53 PM   #2
Unreal
Drives: 2006 Z06
As long as the car was well maintained, mileage should have very little to no effect.
Nick
Corvette Z06 -1200ish rwhp
Old 04-14-2016, 06:44 PM   #3
bradywatt23
Alright thanks! I've done oil changes around 3-3.5k since Ive had it and theres almost 0 oil consumption so I think its in pretty decent shape. I'm not looking for a monster but I would like a good jump in power while still keeping it reliable.
Old 04-14-2016, 08:28 PM   #4
Unreal
Drives: 2006 Z06
As long as compression and leak down are good, no reason to shy away modding a high mileage car.
Nick
Old 04-15-2016, 09:18 AM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Horsepower will break its weakest link, so don't expect anything to not go wrong once you start modding. But as a whole the kit will be a better purchase over some of your other options, in terms of "stress". There are a bunch of high milage FI members here, with no issues.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 04-15-2016, 09:51 AM   #6
bradywatt23
Yeah thats what I was thinking. I only plan on running around 7-8 psi so I don't think that will push it too far. My car is an L99 car and I have issue trusting the AFM lifters so I will probably end up pulling heads and replacing those along with valve springs/pushrods for possibly doing a cam later on. (for lope)
Old 04-15-2016, 12:01 PM   #7
1KillerSS
1KillerSS's Avatar
If your going to do all that, may as well do the trunion upgrade, wont get you any more power, but it will quiet things down, and safeguard things a bit.
Build thread
Old 04-15-2016, 12:55 PM   #8
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
True dat!
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is online now   Reply With Quote
Old 04-15-2016, 01:44 PM   #9
Hard Parker
Hard Parker's Avatar
Drives: ZL1
Awesome question as I am thinking the same
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 04-15-2016, 01:57 PM   #10
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Like unreal said do a compression and leak down test, then if that checks out you are good, and I would probably recommend to do a zl1 fuel pump vs bap when you select your kit since you have over 90k on your current pump, and I will warn you you will have one regret if you end up with the agp kit, and that is why didn't I do this about 90 thousand miles ago.
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 04-15-2016, 02:17 PM   #11
Hard Parker
Drives: ZL1
How easy to do a leakdown and compression
#savethemanuals
Old 04-15-2016, 02:53 PM   #12
Moreair1
Moreair1's Avatar
http://www.hotrod.com/how-to/engine/...akdown-tester/
Here is an article from hot rod or
https://mobiloil.com/en/article
