Old 04-15-2016, 09:27 PM   #1
BUMBLEBEE_SS
BUMBLEBEE_SS's Avatar
Drives: 2010 SS LS3 S200 56/61 AGP TT
AEM water/meth fail safe HELP!
Just starting this year my AEM meth fail safe GREEN LED
starting flashing. 1,2,3,4.....1,2,3,4.... Repeat.
When taking my car outta storage my wratchet crossed the terminals
and arced. Thinking it was a blown fuse I checked them all (that have to do with the accessory) and they appear to be good.
Any idea why this light is flashing?
How can I jimmy rig my pump to ensure it's working?
BUMBLEBEE_SS is offline   Reply With Quote
Old 04-15-2016, 11:33 PM   #2
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
http://www.oakos.com/product_docs/AEM-30-3000.pdf
Nitroman28 is offline   Reply With Quote
Old 04-15-2016, 11:36 PM   #3
Nitroman28
Nitroman28's Avatar
Disconnect the battery then reconnect. And make sure you have enough meth in it.
Old 04-16-2016, 12:12 AM   #4
BUMBLEBEE_SS
�� thank you thank you thank you. ��
Old 04-16-2016, 05:33 AM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Why not trying to put a jumper on the pump, to see if it works? Should be two wires. If there is more than go to the manufacturer's website, and look at a wiring diagram.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
