Old 04-18-2016, 01:12 PM   #1
Colton5
Drives: 2015 Manual V6 1LT RS AGM Camaro
Angry Traction Control Issues
I have a 2015 Camaro that has a traction control problem. At around 10k miles I noticed between 12 and 16mph the traction control light goes off and the car clanks and clunks and it sounds AWFUL. I took it in to get it worked on. The shop had it for a week and "fixed" it. They said they replaced the EBCM (Electronic break censor module". A month later, it started happening again so I took it in and the shop had the car for 2 weeks and then gave it back and said GM has never seen this issue before and does not know how to fix it. I now have the car with this awful issue and it sounds and feels horrendous. They claimed it is a "characteristic of the transmission" What kind of lazy crap is that answer? This is not normal. I have to disable the traction control every time I turn on the car for it to not do it as much. What are my options? I have over a year of warranty left and GM does not want to work on it anymore. Do I go to the dealership manager of which I purchased the car from and go from there? Do I get an attorney? If GM does not know how to fix it, that is fine. I expect a replacement car or a buy back then. What would you guys suggest?
Colton5 is offline   Reply With Quote
Old 04-18-2016, 06:11 PM   #2
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Bring it back again. I think they have 3 or 4 attempts to fix the same problem before the lemon law kicks in
GVA 45TH 2SS is offline   Reply With Quote
Old 04-18-2016, 06:16 PM   #3
Colton5
Ok. Will do.
Old 04-19-2016, 06:06 PM   #4
GVA 45TH 2SS
KNGTFALL
Make sure you have documentation on what you have had them look at/try to fix.
