Old 04-18-2016, 05:14 PM   #1
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
Where do I stop??
So here's the deal the last time my car was on the dyno it put down a good number 638rwhp (not back for an L99 100% stock engine) My injector duty cycle was only at 53% so my question is should I raise the boost until I'm at say 70-80% duty cycle and call it good
let me know your thoughts, my list of mods are in my sig.
scv_guy is offline   Reply With Quote
Old 04-18-2016, 05:43 PM   #2
Unreal
Drives: 2006 Z06
That would probably be in the 850ish range. Not only will the motor not like that, you are already at the limits of the factory transmission. Can't go much farther without touching that.
Nick
Corvette Z06 -1200ish rwhp
Old 04-18-2016, 05:47 PM   #3
scv_guy
scv_guy's Avatar
Well I'll be honest I'm one of the guys that built a 6L80. The trans was just gone through less then a month ago. It has all good parts and "should" hold the power time will tell..
Old 04-18-2016, 06:00 PM   #4
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
How about a turbo cam and replace the lifters. And raise the boost a bit
ttshovel is offline   Reply With Quote
Old 04-18-2016, 06:04 PM   #5
scv_guy
scv_guy's Avatar
I could be wrong, but ultimately the outcome would be the same more power then some parts can handle. That being the case why spend the money on the cam swap?
Old 04-18-2016, 07:52 PM   #6
ttshovel
ttshovel's Avatar
The afm lifters aren't the greatest, I would personally swap them if you're raising boost even more. But thats just me. And it doesn't take but a couple hours to do a cam swap anyways. That's why I was suggesting it. Plus it would give you the opportunity to install head studs or arp head bolts
Old 04-18-2016, 07:53 PM   #7
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
The L99 valve train is the weak link. By doing the complete cam kit you could have a broader power band and you could safely raise your rpm to 6800.
SS PANTHER is offline   Reply With Quote
Old 04-18-2016, 07:58 PM   #8
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
Keep going until it stops making power
supergt99 is offline   Reply With Quote
Old 04-18-2016, 08:17 PM   #9
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Posted this in the Tune Section where you ask the same question:
IDC is only part of your limitation to the final equation. Usually, the dual fuel pump will limit you before the bigger injectors you have. And this is only a suggestion - from my research, a stock LS3 is good for 700-750bhp. You have a L99, so I'd presume a bit less with that, and with your 638rwhp, that amounts to 751bhp. IMO, you're riding on the edge right now. Do what you want, but a stocker, when pushed, will only hold so much power, for so long, until something gives... just my simple two cents worth.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 04-18-2016, 08:39 PM   #10
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Forge the engine and see how much fuel you have.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
