![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS Join Date: Oct 2014
L99 Cam With Turbo
Seeing if anyone is running on with their turbo? What kind of power did u make? I was told u won't get a real chop sound because of the turbo?
I would be doing the LS3 conversion. |
#2 | |
![]() ![]() ![]() ![]() Drives: 2010 Camaro SS Join Date: Jan 2015
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
You absolutely can get cam "chop" with a turbo cam. I'd have ljms spec you a cam
Too much is never enough!
I get a decent chop, not anything drastic, but that's all in my cam specs. I'm not an l99 but I do have turbos.
I was told it would be 1800 in parts including the LS3 conversion, DOD Delete Kit, and cam. Sound about right? Or should I just source my own parts.
#6 |
Forged Pistons and rods too?
#7 |
#8 |
Spend the extra money and get forged Pistons and rods. At least I would I think I had a grand in those parts I can't remember. In total I spent about 2800 for everything.
#9 |
#10 |
ttshovel built the motor for me.
#11 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Honestly if you base a cam choice on sound your doing it for the wrong reasons. Optimal performance should trump cool factor especially when it comes to a vital part of your performance package.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Agreed but this board loves pretty and cool sounding.
Nick
Corvette Z06 -1200ish rwhp |
#13 |
I understand the performance aspect of it I was just asking if u get the chop sound since most have that and was told u don't.
#14 |
So is anyone running a performance cam on a L99?
