Old 04-19-2016, 08:49 AM   #1
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
Overheat?
Today on the way to work I had a message pop up on my DIC. It said " AC off due to high engine temps" . Sure enough, I look at the temp gauge and its pegged. I drive another 2 blocks and the needs moves waaaay back to normal temp and it didn't do it again. I ran the codes and I have nothing besides 02 codes (no cats or tune yet). Can this just be a fluke? Im going to go check my fluid levels when I go on lunch and the car is cooled off. Anything else I should look at?
Thanks
Adam
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is offline   Reply With Quote
Old 04-23-2016, 04:26 PM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
How long had you been driving? Sounds like the thermostat was stuck closed, and then opened, lowering the coolant temps. Might be time for a new t-stat.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
