Old 04-19-2016, 10:49 AM   #1
2SSJEFE
2SSJEFE's Avatar
Drives: 2012 45th Anniv 2SS L99
AGP Install
I was hoping I could get a copy of someone's AGP install instructions so I can look it over to see all that is involved. Does anyone know the turbo models that are offered in their kits? Specifically the 54/57 BallB Garrett .63 afr and the 54/57 BallB Garrett .82 afr.
2012 2SS 45th Anniversary L99
Kenne Bell 2.8 LC, Kooks Headers, QTP Cutouts, Magnaflow exhaust, ZL1 body and brake conversion, Ridetech Lvl 3 coilovers.
2SSJEFE is offline   Reply With Quote
Old 04-19-2016, 11:11 AM   #2
Unreal
Drives: 2006 Z06
Call Kevin or email.
Really it is just unbolting parts, then bolting back on. No drilling, no tapping, no cutting, no modifying. Comes with everything. Super simple and should take a full 8-10 hours first time, but nothing is hard.
Turbos models can be 1000 different combos. They offer BW, Garret, Precision, AGP, and in a mix of tons of different housings and combos. Billet or cast, different outlets, different compressor housings, etc. Best to call and discuss your goals and then get the best setup for what you want.
Nick
Corvette Z06 -1200ish rwhp
Old 04-19-2016, 11:34 AM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
shoot me your email address, ill send you a copy of my instructions, If you cant get them.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
