Old 04-19-2016, 11:34 PM   #1
Jeff65SS
Jeff65SS's Avatar
Drives: 1965 Chevelle Malibu SS
Thermostat change instructions?
Anybody got a link or walkthrough of just what is needed when changing out the ZL1 thermostat? I know it is pretty easy, just want any helpful hints available. Thanks in advance.
Jeff65SS is offline   Reply With Quote
Old 04-20-2016, 11:42 PM   #2
Buckley12
Drives: 2013 zl1
If you can, pinch off the radiator hoses and then it's justill 2 bolt holding on the housing. Pull the housing off and theirs the thermostat. Place the new on in the same way the old one comes out and then put the housing back with the 2 bolts and unclamp the hoses. Yours still going to losing what ever is in the block so place rags down under the housing area or put car in the air and remove the belly pan
Buckley12 is offline   Reply With Quote
Old 04-21-2016, 07:55 AM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
leave the radiator hose attached to the housing and use a 10mm socket to remove the retaining bolts. Remove old thermostat and replace with new unit. Make sure to align the notch on the gasket with the housing notch. Tighten the housing evenly and don't over torque the bolts.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-21-2016, 08:42 AM   #4
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
You have to put a new gasket on? I was told there was a rubber O ring on the T housing and it does not need to be replaced. Correct?
Bigtime53 is offline   Reply With Quote
Old 04-21-2016, 09:57 AM   #5
Stephen12ZL1
Drives: '21 ZLE A10
gasket is a O-ring rubber seal that is around the thermostat and not on the housing
Old 04-21-2016, 11:24 AM   #6
Buckley12
Drives: 2013 zl1
These is also an O ring on the block. So yes you are correct with leave that one alone it will be fine
Old 04-21-2016, 12:40 PM   #7
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
Estimate on how much coolant you will lose?
jayno20 is offline   Reply With Quote
Old 04-21-2016, 01:33 PM   #8
BeachBum
Drives: 2012 (ZL-1) #468
Wanted To Change Out My Thermostat To A 160 Degree - Dealer Advised Me It Would Throw A Code - Any Truth To That?
BeachBum is offline   Reply With Quote
Old 04-21-2016, 04:59 PM   #9
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
No it will not throw a code.
Old 04-21-2016, 11:49 PM   #10
Buckley12
Drives: 2013 zl1
I don't know how much you'll lose. I ended up draining all of it and then someone gave me that clamp off the hoses idea. Sorry
Old 04-22-2016, 05:46 AM   #11
rjs2010SS
rjs2010SS's Avatar
Drives: 2013 AGM ZL1 BELLA*
It doesn't seem it is worth doing to be honest. Just my opinion. If somone can break down why it is worth doing I'm all ears.
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella*
2010 MGM Toyota Tacoma
2010 CGM SS (Traded)
1996 Black SS (Sold)
rjs2010SS is offline   Reply With Quote
Old 04-22-2016, 06:36 AM   #12
keith.wilkinson.10
keith.wilkinson.10's Avatar
Drives: 2010 2SS/RS IBM
Use the search button, or google. Don't change to 160 TStat this is myth and it is busted more wear in long run.
Sent from my SAMSUNG-SM-G890A using Tapatalk
keith.wilkinson.10 is offline   Reply With Quote
Old 04-22-2016, 12:55 PM   #13
Jeff65SS
Jeff65SS's Avatar
Thanks for the replies. I had a lingenfelter 630 package installed which included a 160 thermostat. I believe the thermostat has gone bad, so I am just replacing it with what was already installed at my local speed shop.
Old 04-22-2016, 01:04 PM   #14
jayno20
Go fast, please.
jayno20's Avatar
No one has ever PROVED more wear. It's all just opinion from what I've seen.
