Old 04-20-2016, 05:57 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
Make sure your rear cradle doesn't move with LG Solid Mounts!
LG Motorsports Solid Camaro Gen5 Subframe mounts.
Tired of not being able to put the power down like you should in your new Camaro? Wheel hop still an issue? Nervous feeling under braking or through a fast corner? With LG Motorsports solid subframe mounts you can now completely remove any movement of the factory Camaro rear subframe cradle. This will give you a better feel for the car as the control arms, shocks, and springs will be doing their job rather than moving the cradle. Drag racers, road racers, and street cars will all benefit from this by giving you more forward bite on the car and a smoother more controlled launch. No more will the car feel nervous through the corners or under hard braking.
Our kit comes with both forward and rear mounts and precise aluminum sleeves to positively locate your cradle in the car.
Street car customers will still find this a good modification as the control arms and differential are still mounted in rubber to isolate this from road noise.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 04-20-2016, 08:07 PM   #2
KevHao
Drives: 2013 Camaro 2ss/RS LS3 6MT
Pm your solid price please.
KevHao is offline   Reply With Quote
Old 04-20-2016, 11:26 PM   #3
Motorboy8769
Drives: 2015 2ss
Pm a price please.
Motorboy8769 is offline   Reply With Quote
Old 04-21-2016, 07:20 AM   #4
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
What material are these constructed from?
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 04-22-2016, 06:55 PM   #5
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
Pm me a price .
briancamaross is offline   Reply With Quote
Old 04-24-2016, 10:20 AM   #6
Yippee38
Yippee38's Avatar
Drives: '11 SGM 1LT/RS, '02 SOM Firehawk
I too would like to know what material these are made from.
Yippee38
Yippee38 is offline   Reply With Quote
Old 04-25-2016, 12:27 PM   #7
Delrin and aluminum because they are lighter that way and will not move under hard abuse.
We have ran this same setup in the Camaro race cars since 2010
Old 05-02-2016, 02:36 PM   #8
For those interested I have a GP going on right now too!
Old 05-02-2016, 02:42 PM   #9
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
Please PM price, shipped to 85295
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
Old 05-02-2016, 02:58 PM   #10
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Price?
camarosspower is offline   Reply With Quote
Old 05-03-2016, 04:42 PM   #11
PM's returned! Let me know if I missed anyone.
Old 05-29-2016, 11:22 AM   #12
KiloRomeo
Drives: YES
Anthony, empty your inbox so that you can receive PM's.
KiloRomeo is offline   Reply With Quote
Old 06-01-2016, 12:26 PM   #13
Should be open now.
Old 06-03-2016, 03:35 AM   #14
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
price shipped?
JT Camaro is offline   Reply With Quote
