Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 04-20-2016, 05:58 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
Make sure your rear cradle doesn't move with LG Solid Mounts!
LG Motorsports Solid Camaro Gen5 Subframe mounts.
Tired of not being able to put the power down like you should in your new Camaro? Wheel hop still an issue? Nervous feeling under braking or through a fast corner? With LG Motorsports solid subframe mounts you can now completely remove any movement of the factory Camaro rear subframe cradle. This will give you a better feel for the car as the control arms, shocks, and springs will be doing their job rather than moving the cradle. Drag racers, road racers, and street cars will all benefit from this by giving you more forward bite on the car and a smoother more controlled launch. No more will the car feel nervous through the corners or under hard braking.
Our kit comes with both forward and rear mounts and precise aluminum sleeves to positively locate your cradle in the car.
Street car customers will still find this a good modification as the control arms and differential are still mounted in rubber to isolate this from road noise.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 04-21-2016, 07:45 AM   #2
Lonewolf583
Apex Predator
Lonewolf583's Avatar
Drives: 2010 2SS/RS M6 Rally Yellow
I'm assuming this is poly/delrin w/ the Al insert?
2010 Camaro 2SS/RS - LS3/TR6060, Paid Off \o/
Beating physics into submission since 1991.
Lonewolf583 is offline   Reply With Quote
Old 04-25-2016, 12:30 PM   #3
Delrin with aluminum, same thing we have been running in the race cars since 2010
Old 05-02-2016, 02:36 PM   #4
For those interested I have a GP going on right now too!
Old 05-03-2016, 12:18 AM   #5
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
It's crazy how much solid bushings are!!!
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 06-20-2016, 06:22 PM   #6
Sale ends June 30th!
