Old 04-21-2016, 01:11 PM   #1
Feeweezy7
Drives: 2011 Chevy Camaro LT1
Unhappy 2011 camaro LT MAF sensor change help?
I have a 2011 LT about 59k on the dash, the other day I started experiencing problems. The check engine light is on my car shakes at idle, and slow acceleration when in drive. I had the CHeck engine light code read and got 17 of them all random misfires ex. P0300,P0306 and etc and a Mass Air Flow sensor code.. I just replaced the sensor and it's still doing the same thing., any thoughts on might be wrong and where to go next??
Feeweezy7 is offline   Reply With Quote
Old 04-21-2016, 01:13 PM   #2
tonysplanb
tonysplanb's Avatar
Drives: 2014 1SS
If you have a Cold Air Intake, check the hoses to see if they are loose. You will hear a slight hiss if this is the problem
tonysplanb is offline   Reply With Quote
Old 04-21-2016, 01:55 PM   #3
Feeweezy7
I have a spectre cold air intake, before having this problem I always heard a whistling noise when accelerating. I will check the hoses tho, I have a ? After changing the sensor was there anything else I needed to do? I know the computer prob was reading the old sensor I'm wondering if putting a new one in that it would pick up on the new sensor
Old 04-21-2016, 01:58 PM   #4
ShortBlock
Camaros of NorthWest Ohio
ShortBlock's Avatar
Drives: 2012 LS
Disconect your battery for about 15 minutes or so to clear the codes in the computer and then u should be fine.
Sent from my SM-G900P using Tapatalk
2012 ls 20in rims,cai,oil catch can,throttle body spacer,billet grill,axle back exhaust,vitesse throttle control,red oracle headlight halos, red oracle afterburner taillights,blacked out windows,oem strutt tower brace polished and painted
ShortBlock is offline   Reply With Quote
Old 04-21-2016, 01:59 PM   #5
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Your throttle body sensor could be going bad.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 04-21-2016, 02:09 PM   #6
Feeweezy7
I will try that method, where is the battery located ? I didn't see it under the hood
Old 04-21-2016, 02:10 PM   #7
Feeweezy7
I'm new to this car stuff so I don't know much about camaros I just got one for looks and power lol but you think I should replace that also? It's a new car only 59k I got it with 47k on it still mint
Old 04-21-2016, 02:13 PM   #8
ShortBlock
ShortBlock's Avatar
Drives: 2012 LS
Its in the trunk under the floor mat in the middle..you will need a 10mm to remove the neg ( black cable )
Old 04-21-2016, 02:43 PM   #9
Feeweezy7
Thanks, so am I'm removing just the black cable? & Leave the red connected ?
Old 04-21-2016, 02:44 PM   #10
ShortBlock
ShortBlock's Avatar
Drives: 2012 LS
Yup..
Old 04-21-2016, 02:49 PM   #11
Feeweezy7
Yup..
Ok im doing it now, seems that my floor mat in my truck isn't coming up? Do I need to unbolt something ?
Old 04-21-2016, 02:51 PM   #12
ShortBlock
ShortBlock's Avatar
Drives: 2012 LS
No it just lyes there
Old 04-21-2016, 02:53 PM   #13
ShortBlock
ShortBlock's Avatar
Drives: 2012 LS
U have to get the edge of it and pull up..then in the center there a ring u unscrew and the the hard peice comes up then theres ur battery
Old 04-21-2016, 02:56 PM   #14
Feeweezy7
I got it now, didn't know it had a center ring.. So wait about 15mins n then plug that black cable back up? N hopefully this should fix it, if that's the case
camaro lt/rs, maf sensor, misfire, engine, v6, 2lt
