juicehead2004
Drives: 2010 Camaro SS Join Date: Jun 2013
2010 Ls3 oil pump swap
I have a 2010 ss ls3 and my oil pump failed. Shut it down in time and saved the engine , I bought a Melling 10295 to replace it with.. My question is install.., I called a local shop and they tried to quote me 13-14 hrs and claimed u have to unbolt the whole engine from the mounts to replace pump. But I see a bunch on here saying it's no more than a 4-5 hour job and nothing about pulling the motor.. Can someone please let me know what needs to be done to replace the pump , a quick step by step.. Doesn't have to be super detailed just a quick guide so I know what I'm looking at please.. Thanks for any help in advance guys..!
2010 Camaro 2SS/RS LS3- Inferno Orange w/ Black racing stripes
ADM CAI-SW 1 7/8 LT headers-SLP Powerflo Exhaust-PCM "545" Cam-BTR Springs-BTR pushrods-C5R chain-Melling oil pump-SLP 25% UD-SLP 160* stat-MGW Shifter- 469 rwhp/ 452 rtq |
'It's an experiment'
My build shows a heads Supercharger, and cam install, but it includes the oil pump removal and installation. Starts around page 6 if you want to see what is involved. Had to drop the pan to get to one bolt, and that one bolt on the oil pump pickup tube is a pain...
-Don
747 RWHP 794 RWTQ
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Alldata shows 10.6 hours. That being said, you'll be unlikely to find a shop willing to do it for less regardless of how long it takes them to do the job.
Definitely don't have to pull the motor to replace the oil pump. Find another shop....NOW!!!
As Hammdo stated above, the oil pump pick-up tube bolt is difficult, however, if you have a flex-head, ratcheting 10mm wrench, it makes removal/install of that bolt a whole lot easier. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 13' 1LE Join Date: Apr 2012
You can lower the oil pan by 3/4 inch by loosening the bolts. It gives you enough space to unbolt the pump from the pick up tube. Its a tiny space to work in, but definitly doable.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
#6 |
Yep, pretty much what I had to do, drop it just enough, flex head ratchet, and hemostat clips...
Can be done, but it is a lot of labor... -Don
747 RWHP 794 RWTQ
#7 | |
100% Chevy & Harley Man
Drives: 2010 2SS: Blown LSX 376-B15 Join Date: Feb 2009
i hope yours is not the same. I was lucky enough to be able to put in a LSX-376 B15 long block, with original Maggie and a few other items. Final tune turned 765 HP/686 lbs of torque (Flywheel). So all is good now, but after many painful nights. Good luck.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
#9 |
![]() Drives: 2010 SS. YSI and Built 416 Join Date: Jul 2015
I kept loosening all my bolts on my oil pan and had them all almost all the way out. It was a pain in the ass and finally just took all the bolts out. Next time I didn't screw around. I just took all the bolts out and lowered the pan.
#10 |
I left just one bolt on the left side just to keep the pan aligned...
-Don
747 RWHP 794 RWTQ
#11 |
juicehead2004
Thank u to everyone who posted I appreciate all the help..
#12 |
![]() Drives: 2014 SS Join Date: Apr 2015
Should probably cam swap since you'll have the pump off LOL
Don't forget to shim the pump unless you're doing the LS pump
Toys:
2014 SS - TSP 235/239, CAI, LT's, 12.2 @ 115 ("SLOWLY" chipping away ET) 2000 Trans Am - Bolt-ons 13.0@110 (sold) 2009 YZF R1 - Race bike (road course)(totaled racing) 2008 YZF R6 - Race bike (road course)(still own) |
#13 | ||
View this..not sure if shims are ''needed or not'', they stated ''for performance application''. Well I did not use shims...I didnt know. Oil pressure is strong cold at 60psi, 30 hot idle and 38-40 cruising.
13' 1LE
#14 |
With my LLT I was always worried about a failure related to timing chains or bearings...
Now I'm watching my damn oil pressure like a hawk anytime I start the car! I hope this is a relatively low rate of occurrence, or I'm going to end up with an ulcer
