Old 04-23-2016, 12:43 AM   #1
atn
atn's Avatar
Drives: 2012 ZL1 Silver Ice
Sunoco ultra 93 question
Total new be here I've only driven my new to me ZL1 56 miles so far.
Sunoco ultra 93 non ethanol gasoline has been recommended to me. When I went to fill up the sign on the pumps say ultra 93 but the selection button said minimum octane 90. So is this really 93 octane appears I may be running 90. Or am I just paranoid
atn is offline   Reply With Quote
Old 04-23-2016, 03:13 AM   #2
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
Paranoid. I only run 93 octane Sunoco ultra. My car runs great with it. I've be running for 3 years now and 5000 miles. Sometimes I add a little turco. Good luck
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 04-23-2016, 07:20 AM   #3
Scotty D2014
Drives: 2014 SS1-1le Crystal red metallic
93 ultra only here also
Scotty D2014 is offline   Reply With Quote
Old 04-23-2016, 08:07 AM   #4
Sheriff Justice
If your not 1st your last
Sheriff Justice's Avatar
Drives: 2014 Camaro 2SS / RS
When I had my new Pontiac G8 GT ('09 - '14) and I used Sunoco 93 it would always throw a CEL. Visit to the dealership for code explanation and they told me it's the gas because Sunoco contains a lot of ethanol (up to 10% max). Now today I occasionally use Sunoco 93 in my '14 Ram 1500 5.7L V8 with no issues or problems.
From delivery of my '14 Camaro SS I only go to 'top tier' gas stations and get octane 93. For me locally it's Shell, Mobil, Exxon or BP. Top tier gas stations are under agreement / contract to include a specific treat rate and additives to the fuel. Click link for good info.
http://www.toptiergas.com/retailers/
2014 Camaro 2SS / RS ~ Blue Ray Metallic w/ Silver Rally Stripes ~ V8 6.2L ~ Blue & Black 2-tone leather interior accent trim package ~ Custom decals from Emblem Pros
Sheriff Justice is offline   Reply With Quote
Old 04-23-2016, 10:44 AM   #5
Dutchman427
Drives: 2012 ZL1 #1329 M6
I used to run Sunoco Ultra 93 only. I still do if there is no Shell in the area. I really like the Shell 93 V-Power. But there is only two stations in my area.
Dutchman427 is offline   Reply With Quote
Old 04-23-2016, 12:20 PM   #6
cal45
cal45's Avatar
Drives: 2015 Blue Velvet Metallic ZL1
Shell 93 V-Power here also from day 1 with mine.
cal45 is offline   Reply With Quote
Old 04-23-2016, 12:44 PM   #7
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Must be nice to have 93 octane available...
I have to use Torco
Mods:
Old 04-23-2016, 07:50 PM   #8
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I have to use Torco
Leave that place of fruit and nuts and you can get 93...
-bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 04-23-2016, 07:52 PM   #9
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I use Shell Vpower, I used to use Sunoco but I always felt the gas ran thru my tank really fast, sounds silly but, LOL. Seems the Shell lasts longer.
Old 04-25-2016, 02:31 PM   #10
m3andak
m3andak's Avatar
Drives: 2013 Camaro ZL1
Shell V-Power 93 up here in NH but when I lived on Long Island I use to get Sunoco Ultra 94.
m3andak is offline   Reply With Quote
Old 04-27-2016, 10:52 AM   #11
jgc2430
Drives: 2014 ZL1
does anywhere in the northeast still sell 94?
jgc2430 is offline   Reply With Quote
Old 04-27-2016, 11:54 AM   #12
RJ111
RJ111's Avatar
Drives: 2015 ZL1
There is no such thing as 93 Non E anymore. They stopped making it. The highest octane you can get now in the non E is 90. The sticker on the pump is right.
2013 Camaro ZL1,Victory Red # 441....SOLD
2013 Camaro ZL1, Summit White # 3071...SOLD
2015 Camaro ZL1, Summit White # 1325
Rotofab Cai,PCM cc,Kooks Headers,Cats delete,MF X pipe, ZLWin cam,upper/lower, Lingenfelter hx,715 rwhp,646 rwtq, BMR 1.25 Springs, Varro VD01 Wheels,
RJ111 is offline   Reply With Quote
Old 04-27-2016, 11:59 AM   #13
RJ111
RJ111's Avatar
Drives: 2015 ZL1
Yep, you're running 90. I had to switch back to the ethanol blend 93. I was scared to run the 90 in mine.
Old 04-27-2016, 01:27 PM   #14
nvydvr
nvydvr's Avatar
Drives: 2015 Red Rock ZL1
If you were to use Torco, what would be the highest octane you'd want to go on a stock engine?
Alex
2015 Red Rock ZL1
Panama City Beach, FL
nvydvr is offline   Reply With Quote
