04-27-2016, 08:46 AM | #1 |
Drives: 2010 ss inferno orange camaro Join Date: Feb 2016
Craftsman 2-1/2 Ton Floor Jack, Low Profile$39.99
Found this on line. Good Deal??http://www.sears.com/craftsman-2-1-2...9&AID=11042411
04-27-2016, 11:56 AM | #2 |
Drives: Race Car Join Date: Sep 2009
Every Craftsman Jack I have owned lasted until 2 weeks after it went out of warranty!
04-27-2016, 08:13 PM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
You get what you pay for!!!
Orange Krush II
04-28-2016, 09:57 AM | #4 |
Lifestyle = Deathstyle
I would highly recommend this:
And you can carry it
11 2SS/RS
04-28-2016, 10:59 AM | #5 |
I agree on the HF! That's what I use now.
04-28-2016, 09:17 PM | #6 |
Drives: 2010 1ss Join Date: Mar 2016
Ive had amazing luck with harbor freight jacks as well. Used the same one for about 10 years and have never even needed too put oil in it.
04-28-2016, 10:17 PM | #7 |
Lets roll...
Drives: 14' Join Date: Jun 2014
Definitely would not use this one again... I had it and it lasted about 2 lifts on my camaro, before it started spilling its guts out and reseambling the tower of pisa.
Good thing that Harbor Freight tools does stand behind their products, hence why upgraded to the 3 ton super low profile steel jack. Thing is a monster, has been a great jack for the money.
04-29-2016, 11:14 AM | #8 | |
04-29-2016, 11:36 AM | #9 |
Drives: camaro Join Date: Aug 2015
I use the same jack. it's been flawless.
1969 pro street
heads/cam/blown/meth 408 LS |
04-29-2016, 08:15 PM | #10 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
spike III Build IBM 1SS/RS [COTW] 6/25/12
My car is dropped 1" and I have no problem getting this jack under my car. It is an awesome jack.
04-30-2016, 09:53 AM | #11 |
I've got the 2.5 ton HF and it does the job. No complaints
05-06-2016, 11:52 AM | #12 |
Drives: 2012 2SS/RS M6 Join Date: Jul 2011
I am honestly floored (no pun intended) that these HF jacks are holding up. Will keep in mind for the future!
05-11-2016, 04:31 PM | #13 | |
Drives: '15 Camaro 2LS V6 Join Date: May 2016
Sometimes you get good and others you get squawdoosh! I have had bad luck with the jacks at HF. However I have had good luck with their grinders and cut off tools. HF will stand behind everything they sell though, and that in itself might be worth a looky lou |
