![]() Drives: 2015 CAMARO SS LS3 Join Date: Jun 2010
convertible top header panel
Hi all I am having a problem with the header panel inside camaro looks like pass side screws broken off and now major rattle every time hit a bump this is the plastic panel that has the top release handle hardware under it i pulled plastic panel down 1/4 of inch i could see broken plastic inside this part looks like its is fasten from outside before convertible top is put on frame i have no idea how this got damaged and if dealer can repair it without removing roof has this happen to any you guys i
![]() ![]() ![]() Drives: 2023 2SS Convertible Join Date: May 2009
Mine had two cracked screw bosses. My dealer tried to epoxy it last fall, but it has come loose over time. I am headed back there in a few weeks to try again.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
One broke on my driver side and was rattling, I cured it with very high strength 3m double sided tape, it's been over a year and a half and still rattle free
Cai intake and a few other mods😎
![]() Drives: 2014 2SS/RS VERT Join Date: Mar 2015
That panel is all one piece when replaced by the dealer. My handle got a little loose and they had to replace the entire panel as no parts could be ordered for the panel. So basically, if you can't come up with a fix, they will have to replace the whole thing. The top does NOT have to be removed though. Good luck.
2014 2SS/RS Vert.
"Today I didn't even have to use my AK, I got ta' say it was a good day" |
Camaro: A Legend Reborn!!
Yup mine broken too!
I think you have to do something with the top to access the screws that hold the panel on if I am not mistaken?
Mine is broke as well and I want to do it myself but it appears the top needs to come back enough to access the fasteners.
[SIGPIC][/SIGPIC] |
#6 | |
#7 |
Dealer doing a recall broke mine but I didn't realize it till later
#8 | |
I was just at the dealer today, and it looks like they will replace my top under warranty (if they decide it was a wear issue) so I plan on getting this panel replaced too. -Geoff
#9 |
I could pry my trim piece down some from the driver seat, and then inserted something similar to this and haven't had an issue since and it has been like 1 or 2 years
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2LT RS Convertible Join Date: Jul 2011
That's some seriously sticky 3M tape!!! Terrific stuff!
Summit White Black Leather 3 Pedals Build Date: 06/27/2011 Purchased: 07/30/2011 Title Received: 08/15/2011 1984 Camaro (3rd Gen.): Traded: 1987 "Meet the new boss. Same as the old boss." |
#11 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Just had mine break for the third time, warranty ended in april. Last replacement lasted just anout a year.. Not happy, opened a case with GM Customer service. I suggest everyone with this issue do the same.
The Bird is the word! |
#12 |
Is there an updated part or will GM put same part that keeps breaking on ?????
#13 |
Probably the same stupid part. If they refuse to fix mine again and if I can figure how to get it removed I am going to design a part on my 3D printer to re-enforce those bosses.
#14 |
Quit being a pu$$y
Mine has been bugging me for a while. Finally took it out today to try and fix it, three of the four bosses were broken. Hope this fix lasts. Luckily the replacement part is only $35. Took all about 5 minutes to remove. It's not hard at all. Just a bunch of torx 25 bolts.
They break because it's a shitty design.
