Old 04-29-2016, 05:00 AM   #1
nidecker
nidecker's Avatar
Drives: 2014 2SS/RS 1LE, Supercharged
Z28 brake kit - ever installed on SS, 1LE or ZL1?
This forum is an outstanding source for any kind of information and help!
Just fixed my AEM AFR gauge problem with your support.
Now I´m investigating if there is any experience with a Z28 brake upgrade done on SS, 1LE or ZL1?
Thanks for sharing
nidecker is offline   Reply With Quote
Old 04-29-2016, 09:30 AM   #2
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
The difficult part will be finding all the brake components needed. The calipers and rotors I believe are restricted parts with GM. Meaning you cannot order them through GM without having a valid VIN and matching owners name for a Z/28.
Not only that buying all the components would be very expensive. Rotors alone would cost $1500+ each for the fronts. Not sure what the rears are listed at.
Most people that want upgraded brakes for track performance are going with a ZL1 style set up (aka CTS-V setup). If I find out I need more braking performance after this weekend at Road America I will be saving my money for the AP Racing kit offered through Essex. Look for Summit1LE's thread on these.
Nick S is offline   Reply With Quote
Old 04-29-2016, 09:55 AM   #3
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
No parts restrictions any more. There are better options that dont cost almost 10 grand
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 04-29-2016, 10:36 AM   #4
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
The Z/28 rotor upgrade cost $10K ??
For that price I can add a supercharger and all the other goodies needed to get like 150rwhp more at the very least.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 04-29-2016, 10:46 AM   #5
Airway Monkey
Airway Monkey's Avatar
Drives: 2015 2SS/1LE
True....but you don't buy a supercharger and all the other goodies needed to get 150rwhp to help you stop at the end of a long straight away.
And if you look at Dropspeed, X25, Summit1LE's threads....there are options out there. From the budget minded racer to someone who wants the very best track performance to those who want the track and the street balanced in a nice aggressive brake package. Lots of good reading on these forums regarding what has worked for those in the past and lessons learned.
Matt
Airway Monkey is offline   Reply With Quote
Old 04-29-2016, 11:29 AM   #6
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
http://m.ebay.com/itm/OEM-NEW-BREMBO...764?nav=SEARCH
Quick search came up with this. 9.7k for the whole kit. The. If you track you have to factor in replacing the rotors and pads at a few thousand each time
2014 1SS/1LE
Old 04-29-2016, 12:43 PM   #7
blackoutVIII
blackoutVIII's Avatar
Drives: 2011 2SS w/RS PKG
If I had that amount to spare, I would FI, clutch, drive shaft, and rear gear upgrade!!!
ACS T4 Splitter
ACS T4 Wind deflectors
Z/28 Spoiler
VMAXX TB
SLP Short Ram Blackwig CAI
Stainless Works Headers w/Hi-Flow Cats
blackoutVIII is offline   Reply With Quote
Old 04-29-2016, 07:24 PM   #8
summit1le
Drives: 15 Lexus RCF, 17 Vette Grand Sport
You can safely use your factory 4 piston brembos and upgrade to a basic track set up like the cts v, then stoptech, then a set of AP racing radicals or forged monoblock brembos as those do cost an arm and a leg. If interested hit up Jeff at Essex parts for the AP set up. If you are truly interested in tracking, unless your pockets are filled with endless cash I don't know anyone that hasn't thought about it replaced carbon ceramics with a steel set up
2013 Summit 1SS 1LE w/NPP, SW 1 7/8" Long Tube Headers, CAI Intake, Ported TB, Cammotion 224/232 113 LSA, BTR Valvetrain, Melling Oil Pump, 468 HP 423, Apex Catch Can, Tank Plates, RPM 4 Point Roll Bar with SCCA/NASA Cross Brace, Schroth 6 Point Han's Harness, OMP WRC Front Seats, F.M.T Trailing Arms, F.M.T Solid Aluminum Subframe Bushings, Moreno Motorsports Camber Plates, BMR Bushings Front and Rear, Essex/AP Racing Radi-Cal Endurance Front Brakes, Quantum Brake Cooling Ducts, ZL1 Rockers, ZL1 Air Deflectors, Heritage Grill, Pfadt Springs.
summit1le is offline   Reply With Quote
Old 04-29-2016, 07:26 PM   #9
AG1LE
AG1LE's Avatar
Drives: '14 1LE
http://www.ebay.com/itm/Brembo-OEM-G...wAAOSwX~dWsMo3
$7200
AG1LE is offline   Reply With Quote
Old 04-30-2016, 02:10 PM   #10
hammdo
'It's an experiment'
hammdo's Avatar
Originally Posted by AG1LE View Post
Wow... That is not bad... As long as the knuckles are the same, that is about the price of the ZL1 kit...
-Don
747 RWHP 794 RWTQ
Old 04-30-2016, 09:36 PM   #11
Nick S
Nick S's Avatar
So if the brake parts are off restriction does that mean the wheels are off restriction now as well?
Old 05-01-2016, 12:39 PM   #12
nidecker
nidecker's Avatar
Hi guys, I do appreciate your advice, and well I know of all the cons + cons about the ceramic.
I just wanted to know, if there is any experience with non Z28 upgraded to the Z28 brake package - e.g in regards to the suspension behaviour, daily driving, track experience,...
Keep in mind, that an upgrade to a 405mm, 6 piston brembo will cost me $4.700 - just the front...so $7-8.000 expense with a 4-5 times longer lifespan is an option.
Old 05-10-2016, 06:23 PM   #13
ZL1-V
Drives: 2013 Camaro ZL1
I did a prototype carbon ceramic system for our cars through Racing Brake. I would be hesitant also If I had paid retail. Funny thing is some owners will drop that much in an engine build and not blink an eye. The other alternative is the AP Racing setup. I have used their brakes on another vehicle with good results overall. Not cheap but then again anything worth it won't be. The advantage with the carbon ceramics is better consistency and repeatability at the track when hot! No fading or soft pedal feeling with these brakes! You also can gain longer rotor life especially if you don't track your car every week. Just don't allow it to turn into a "bling mobile" rather than a track day machine.
ZL1-V is offline   Reply With Quote
