Old 05-01-2016, 09:35 AM   #1
96_2010_CAMARO
96_2010_CAMARO's Avatar
Drives: 2012 SIM Camaro 2SS/RS , 2010 Tahoe
Send a message via MSN to 96_2010_CAMARO
Lightbulb Highbeam response ?
Is it possible to make the high-beams responds faster (Rs headlight ) cause when I try to flash twice it only flashes once . in the place I live every flash means something so I'm having a hardtime in our streets .
2012 2SS/RS silver ice metallic camaro
96_2010_CAMARO is offline   Reply With Quote
Old 05-01-2016, 11:22 AM   #2
EWade
EWade's Avatar
Drives: 2015 Camaro LS
Nope
15 LS in Blue Velvet
EWade is offline   Reply With Quote
Old 05-01-2016, 11:25 AM   #3
davepnw
davepnw's Avatar
Drives: 2010 2LT, switchblade silver
Push the lever slower?
"It's what you learn after you know it all that counts"
davepnw is offline   Reply With Quote
Old 05-01-2016, 04:05 PM   #4
96_2010_CAMARO
Thanks but I was looking for a mod that makes the lever more sensitive
Old 05-01-2016, 04:06 PM   #5
96_2010_CAMARO
Bump :(
Old 05-01-2016, 04:52 PM   #6
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
Dont think there is. Do a search on it.
Ledzepx is offline   Reply With Quote
Old 05-01-2016, 07:09 PM   #7
el-guapin
Trust No One!
el-guapin's Avatar
Drives: 2010 SIM 2LT/RS
Be careful!. Rapid flashing can actually or eventually cause an issue with the electric motor that controls the flap inside the housing that allows more light to pass. It can cease and stay open/closed then you will need to take the housing apart to replace the motor or replace the headlight entirely.
el-guapin is offline   Reply With Quote
Old 05-01-2016, 08:09 PM   #8
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
If you need it to be more sensitive try stroking it gently and tell it you love it. JK
Hope you figure it out.
HOJO is offline   Reply With Quote
Old 05-02-2016, 03:32 AM   #9
96_2010_CAMARO
