Old 05-03-2016, 01:47 AM   #1
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
Whipple pressure test port on rail
Hey Guy's, can anyone tell me what thread & size is the spare port on the whipple fuel rail, mine currently has a allen key bung in it, I think I have a dam leaking injector giving me hot start issue & want to attach pressure gauge to it to check for leak down while sitting before I have to remove S/C to sort. Also can anyone point me to a shraeder valve I can use with these rails to leave in there permanently, been looking but haven't found anything suitable or will not ship to NZ? Cheers
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 05-14-2017, 12:51 AM   #2
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
What did you find out?
Caswell239 is offline   Reply With Quote
Old 05-15-2017, 08:43 PM   #3
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
should be 1/8-28 NPT.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
