Old 05-04-2016, 10:17 AM   #1
victoryred14
Drives: 2010 2ss
Loose oil filter
I changed the oil in my car 18 months ago. Recently the add oil light came on. I noticed a large oil spot under it. When I put it on my lift, the oil filter was loose, I mean really loose, and oil was draining down the sides. I am unaware of a filter coming loose on it's own. the filter had no exoernal damage or marks. The O-ring looked good.
Does anyone have any idea how this might happen?
victoryred14 is offline   Reply With Quote
Old 05-04-2016, 11:01 AM   #2
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
I've noticed that when using AC Delco oil filters, they have tended to loosen up over time. It's almost as if the gasket was shrinking. I have since used Mobil1 and K&N filters and have not observed this issue.
What brand of oil filter was it?
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 05-04-2016, 12:30 PM   #3
Gayton81
Gayton81's Avatar
Drives: 2012 2SSRS
Loose oil filter
Mine came loose with using a K&N until I drilled a safety wire hole on one of my bolts so now I safety wire the filter to that bolt so it can't come loose.
Money may not buy happiness, but I'd rather cry in a Chevy than in a Ford!
Gayton81 is offline   Reply With Quote
Old 05-04-2016, 07:32 PM   #4
victoryred14
Drives: 2010 2ss
Wix
Old 05-04-2016, 09:22 PM   #5
Scotty D2014
Drives: 2014 SS1-1le Crystal red metallic
I had the same problem when I used K&N !!! I tightened it up more than once.. I'll never use them again ..
Scotty D2014 is offline   Reply With Quote
Old 05-05-2016, 12:10 AM   #6
8balldeluxe
Drives: 2010 Camaro SS Victory Red
Noticed the same thing with AC delco I bought another to see if it happens again, if it does, bye bye AC delco
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
8balldeluxe is offline   Reply With Quote
Old 05-05-2016, 12:50 AM   #7
todd69gs
todd69gs's Avatar
Drives: 2014 Crystal Red 1LE 2SS
18 months?
I'm a firm believer that people are changing their oil way too soon but 18 months might be pushing it. Lol
todd69gs is offline   Reply With Quote
Old 05-05-2016, 02:33 AM   #8
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
Originally Posted by victoryred14 View Post
Wix
This ^^^^
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 05-05-2016, 07:43 AM   #9
victoryred14
Drives: 2010 2ss
I'm sorry, but I don't understand what "This^^^^" means.
It seems that AC delco and K&N are problematic.
Old 05-05-2016, 08:17 AM   #10
DILLIGAF
DILLIGAF's Avatar
Drives: 2023 ZL1 M6 Rapid Blue
It means he agrees with the above statement. ^^ being used as arrows pointing up.
2023 Rapid Blue ZL1 M6
| Corsa NPP | Corsa Carbon Fiber Intake | Hardwired Valentine1 Gen 2 | Pro Clip Phone Mount |
DILLIGAF is offline   Reply With Quote
Old 05-05-2016, 08:20 AM   #11
DILLIGAF
DILLIGAF's Avatar
also this reminded me that my napa gold filter seemed loose when I changed my oil after 5000 miles. I was sure i put it on tighter than what it took to get it off. There was a drop of oil on the bottom of the filter too, wasnt sure how it got there....
Old 05-05-2016, 08:44 AM   #12
myold88
myold88's Avatar
Originally Posted by todd69gs View Post
18 months?
I think it's good insurance. I've done 10 oil changes in 7 years on my L99.
I go by time, not mileage. At least once a year on mine since it's used for
mostly local short trips now.
Old 05-05-2016, 08:57 AM   #13
Gayton81
Gayton81's Avatar
Drives: 2012 2SSRS
I can't speak for AC Delco, but the K&N comes with the pre drilled holes for safety wire for this reason. So why not use it like it is supposed to be and it won't come loose. I didn't safety wire my first one and yes it came loose but after that I always have safety wired it and now it CAN'T come loose unless the safety wire breaks. And using .032 stainless steel safety wire it should not break. I think they are only problematic when not used correctly. This is the same concept race cars use as well as we do on aircraft.
Old 05-05-2016, 09:43 AM   #14
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Yes! Every single AC Delco oil filter will come loose, just like every LS3 oil pump will fail. Oh and don't forget every Comp cam will fail.
There are tens of millions of vehicles running Delco filters with no problem. If your oil filter is loose I would conclude that it was not torqued properly.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
