Old 05-04-2016, 12:49 PM   #1
Ron_MA
Ron_MA's Avatar
Drives: 2014 AGM Trifecta Tuned V6
Anybody have this splitter? Need some info
Any pics or info regarding this is appreciated ! Good or bad .
Ron_MA is offline   Reply With Quote
Old 05-04-2016, 01:32 PM   #2
Trifecta23
Trifecta23's Avatar
Drives: 2013 Dusk 2ss/RS conv.
I dont have that one in particular, but it looks like the stock ZL1 or the special edition splitters(like mine). It changes the look of the front end of your car for the better. If mine didnt come with it, it would have been my first mod.
2013 Dusk Camaro/Convertible/2SS RS/6 Speed Auto/One of Sixty Nine
jdm
Trifecta23 is offline   Reply With Quote
Old 05-04-2016, 03:43 PM   #3
matthew9440
matthew9440's Avatar
Drives: 2010 Camaro 2SS/RS
Any splitter is better than no splitter IMO. I like an aggressive look. I have seen this style before. Its the perfect amount of style. not too bold or out there. Looks factory!
matthew9440 is offline   Reply With Quote
Old 05-04-2016, 05:33 PM   #4
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
Looks good to me but does it come with installation hardware? If not, then where do you but the hardware at?
jcampos is offline   Reply With Quote
Old 05-04-2016, 11:09 PM   #5
SandEngXp
Drives: 2015 Camaro LS+, 2013 Avalanche LTZ
Says it comes with hardware but needs painting on the duraflex site. I am curious about contiur fit up and general surface finish. anyone bought one
SandEngXp is offline   Reply With Quote
Old 05-04-2016, 11:14 PM   #6
MSull16
MSull16's Avatar
Drives: '10 Camaro SS LS3
Id like to fit that and side skirts in satin black if anyone knows a good place to find them.
MSull16 is offline   Reply With Quote
Old 05-19-2016, 06:24 PM   #7
Extreme Dimensions
Extreme Dimensions's Avatar
Drives: 2016 1ss Camaro
if you guys have any questions or need any pricing please let me know!
Andrew Bettridge
Account Manager
Extreme Dimensions
1-714-278-8000 EXT 17
andrew.bettridge@extremedimensions.com
Extreme Dimensions is offline   Reply With Quote
Old 05-21-2016, 09:35 AM   #8
My 3rd Camaro
Drives: 2015 Camaro LS, 2000 Firebird
Just put it on last week. It does come with mounting hardware. You have to purchase the two sided tape though. Wasn't hard. You do need to remove the plastic screws holding on the air dam on the bottom to mount it. I put on weather stripping to make it look better as you can see in the last picture. It didn't quite fit up against the sides and you can see where the two sided tape is showing.
It did come with a hole in it the size of a head of a screw. I just filled and painted it flat black myself. It's withstood 85mph on the highway so it's good but just for looks.
My 3rd Camaro is offline   Reply With Quote
Old 05-23-2016, 08:02 AM   #9
My 3rd Camaro
I'm starting to have problems with it staying on now. Where I put the two sided tape on it's pulling away from the body. This will be the second time I've worked on it in a week. I may have to put more body filler on sections that you put the tape on to bring it closer to the body.
It's only happening on the drivers side.
Old 05-23-2016, 08:49 AM   #10
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
It looks similar to my factory GM splitter. Mine is color matched tho
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
Shawno72 is offline   Reply With Quote
Old 05-23-2016, 10:15 AM   #11
MCSarge
USMC 1980-1990
MCSarge's Avatar
I put 10 bolts in when I mounted mine. Replaced the nuts they sent me with nylock nuts and added a washer on the top and bottom. It has been really solid. Might want to consider adding a few more bolts and not rely on the double faced tape. Good luck on your fix.
USMC 1980-1990
My other toys are Harleys
MCSarge is offline   Reply With Quote
Old 05-23-2016, 10:58 AM   #12
derek1387
Drives: 2015 1LS Red V6
Duraflex?
Gross.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 05-23-2016, 12:22 PM   #13
The Patriot
Drives: 2014 2SS/RS VERT
Originally Posted by derek1387 View Post
Duraflex?
Gross.
Yep, the fit of that splitter is terrible. Weatherstripping, really?????
2014 2SS/RS Vert.
"Today I didn't even have to use my AK, I got ta' say it was a good day"
The Patriot is offline   Reply With Quote
Old 05-23-2016, 12:57 PM   #14
KillboyPowerhead
Drives: 2015 Z/22
Hey Shawno72, when you say factory GM splitter, is that the ZL1 one? Or is there another? Do you know the part number of the one you ordered?
KillboyPowerhead is offline   Reply With Quote
