Old 05-04-2016, 01:16 PM   #1
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Decibel level of Kooks exhaust
All,
Anyone know if Kooks tested the decibel outputs of their exhaust systems?
I have a 1 7/8" long tube headers, high flow cats, and the "sleeper" cat-back exhaust installed on my 2010 SS. I'm looking to export it to NZ, but they have a 90dB noise limit for street use. I downloaded a decibel meter app on my phone and recorded about 80 dB at idle, but i know the tests are a bit more extensive.
Just curious to see if there is already tested data out there.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 05-04-2016, 04:17 PM   #2
bionick
bionick's Avatar
Might want to ask kooks themselves. I'm sure they have all the specs and info
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
