Old 05-05-2016, 05:07 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Question New Slave Needed??
I was bleeding my clutch with the remote clutch bleeder and heard a squinting sound from the bell housing area. I was able to feel in the area as the clutch pedal was being pressed and confirmed it's coming from the clutch line right at the area where it joins with the slave. Is there any fix for this or does the transmission have to be pulled and slave need to be replaced?
booneSS13 is offline   Reply With Quote
Old 05-06-2016, 02:20 AM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you're talking about the line from the clutch master cylinder to the slave? Then ya the trany needs to be pulled. if its the remote bleeder then try to spin it to tighten it up.
JCunningham is offline   Reply With Quote
Old 05-06-2016, 11:14 PM   #3
booneSS13
booneSS13's Avatar
Yeah it's definitely the line from the master cylinder to the slave. Is this normal for these things to leak there? It was fine before I put the motor back in..
brake fluid, clutch problems, manual trans, transmission failure, tremec
